KO3 tire pressure on Trail Hunter?
Crawler
Hi all - I just put KO3s on my trail hunter, and am wondering about correct tire pressure on the tires. Toyota recommends 33 psi on the original tires, but what about KO3s? I just texted with a tire rack rep and he suggested 52 psi. That seems high to me, but he said it would allow the truck to ride at the Toyota-recommended height. Does that make sense to those who know these tires?
Isn't 52psi at or near the absolute maximum of the tire? Sorry to answer a question with a question, but a very relevant spec.
I just checked the sidewall that indicates maximum is 80 psi. So I’m going with 52 and will see how it works out.
Good question — this is really important when switching to E-rated (10-ply) tires like the BFGoodrich KO3s**.** Let’s go through this step by step so you can safely dial in the right PSI for your 4Runner.
1.​
If you have a 2021 Toyota 4Runner Lariat or similar SR5/Off-Road/Pro trim, your stock tires are typically:
  • Size: 265/70R17
  • Load Range: P-metric (Passenger)
  • Max Load (at max pressure):
    • P-metric: ~2,470 lbs @ 44 PSI
  • Toyota Recommended PSI (cold):
    33 PSI front and rear
So your current stock setup supports the truck’s ~6,000 lb curb + payload comfortably at that pressure.
2.​
Your KO3 E-rated tires are built for heavy-duty use, meaning:
  • Max pressure: 80 PSI
  • Max load: ~3,195 lbs each @ 80 PSI
  • Much stiffer sidewalls than stock, so running them at 33 PSI would be too low (underinflated and squishy).
But you don’t need 80 PSI either — that’s for heavy trucks near max load.
3.​
We want the new tires to carry the same load per tire that Toyota intended at 33 PSI.
Here’s how that works:
At 33 PSI, your stock P-metric tire supports ≈ 2,200 lbs per tire.
An LT-E tire supports that same load at about 42–44 PSI.
That’s the sweet spot.
  • Normal daily driving (empty truck):
    Front: 42 PSI | Rear: 42 PSI
  • Heavily loaded / towing / highway with gear:
    Front: 44–46 PSI | Rear: 46–48 PSI
  • Off-roading / airing down:
    18–25 PSI
    depending on terrain
4.​
  • Expect a firmer ride — E-rated sidewalls are stiffer.
  • If it feels too harsh, you can drop 1–2 PSI safely (to ~40 PSI cold) as long as you’re not heavily loaded.
  • Check your tread wear after 1,000 km:
    • Centre wear → too high PSI
    • Edge wear → too low PSI
Excellent question — and yes, E-rated tires do usually need more pressure than your stock P-metric or C-rated tiresto safely carry the same load.
Let’s break it down clearly so it makes sense:
1.​
An E-rated tire (Load Range E) is designed for heavy trucks and trailers:
  • Stronger sidewalls (10-ply equivalent)
  • Rated for 80 PSI max pressure
  • Much stiffer carcass
Because of that stiffness, E tires need higher PSI to flex properly and to carry the same load that a soft, lighter stock tire could handle at a lower PSI.
2.​
Your 4Runner’s stock tires (P-metric or C-rated) typically handle about:
  • ~2,200 lb per tire @ 33 PSI
That’s what Toyota based the 33 PSI spec on — the tire’s load table and the vehicle’s weight distribution.
3.​
Looking at the load inflation charts:
  • An E-rated 265/70R17 KO3 carries ~2,200 lb per tire at ~42–44 PSI
  • To carry its max 3,195 lb rating, it would need the full 80 PSI
So if you inflate your E-rated tires to only 33 PSI, each tire may only carry ~1,800 lb of load — under-inflated for a 4Runner’s real weight. That can cause heat buildup, sidewall flex, and premature wear.
4.​
  • Daily driving (normal load): 40–42 PSI cold
  • Heavy load or towing: 44–48 PSI cold
  • Off-roading / airing down: 18–25 PSI (temporary)
5.​
Even at 40–42 PSI, the E-rated tires will feel stiffer than your factory ones because the sidewalls are thicker. But that stiffness gives you better puncture resistance, load handling, and off-road durability.
✅ Bottom line:
Yes — E-rated tires need more PSI than stock to support the same weight. For your 4Runner, plan to run around 42 PSI cold for everyday driving instead of the original 33 PSI.
Perfect — that makes things nice and specific.
Your Toyota 4Runner TRD Pro comes from the factory with Nitto Terra Grappler A/T 265/70R17 (≈32.6–33″) P-metric tires, not LT. Let’s go through what that means for your KO3 E-rated swap and how to set pressures correctly.
⚙️ Stock Tire Setup (TRD Pro)
  • Size: 265/70R17 P-metric
  • Load rating: ~2,469 lb @ 44 PSI (P-rated)
  • Toyota-recommended cold pressure: 32 PSI front / 33 PSI rear
  • Vehicle weight: ~4,750 lb curb (~1,200 lb per tire at rest, more under braking or load)
So, at 32–33 PSI the stock tires are perfectly matched to the 4Runner’s load.
🛞 Your New Tire: BFGoodrich KO3 Load Range E (10-ply)
  • Size: likely 275/70R17 E (32.8″) or 285/70R17 E (32.7–33″)
  • Max load: ~3,195 lb @ 80 PSI
An E-rated tire is far stiffer; it needs more air pressure to flex correctly and to carry the same weight as the softer P-metric did at 33 PSI.
📊 Load-Equivalent Math
We want each tire to still support ~2,200 lb (same as stock at 33 PSI).
According to BFGoodrich’s load-inflation tables for LT 265/70R17 E:
PSILoad (lb per tire)
35 PSI~1,950
40 PSI~2,150
42 PSI~2,250
45 PSI~2,400
50 PSI~2,570
So, 42 PSI gives you nearly the same carrying capacity as your OEM setup at 33 PSI.
✅ Recommended Pressures for KO3 E on 4Runner TRD Pro
SituationFrontRearNotes
Daily driving / normal load41–42 PSI41–42 PSIClosest to factory load match
Highway / towing / full gear44–46 PSI46–48 PSIImproves stability
Off-road / rocks / sand18–25 PSI18–25 PSIAir back up before highway use
💡 Extra Tips
  • Expect a firmer ride at 42 PSI vs stock 33 PSI.
  • Check wear after 1,000 km:
    • Centre wear → reduce 2 PSI.
    • Shoulder wear → add 2 PSI.
  • Always check pressures cold (before driving or in the morning).
Summary:
Your TRD Pro’s factory 33 PSI is ideal for its soft P-metric tires. After upgrading to KO3 E-rated tires, target ≈ 42 PSI cold for daily use — that restores the same load support and handling balance Toyota engineered, without over-stiffening or running them underinflated.
Daranello - Thank you for this incredibly detailed reply. Your post should go up as a sticky so others can refer to it as needed. I aired down to 42 immediately after reading it. I’m taking a big trip in a few weeks, Maine to South Dakota, and am interested to see how the tires wear over that period. Thanks again!
Met a fellow 6G4R owner today with a stunning...
Hey all, Just wanted to say thanks for the...
As mentioned under Port Installed Options...
Met a fellow 6G4R owner today with a stunning satin PPF wrap on Underground. WOW this looked...
As mentioned under Port Installed Options, Toyota is charging $420 for these Cross Bars: As...
