2025 (6th Gen) 4Runner Tire Rotation Schedule
Extend Tire Life & Maximize Performance
(Reference: 2025 Owner’s Manual, pg. 541)
Rotating your tires regularly is one of the simplest and most effective ways to extend tread life and maintain even wear across all four corners. Uneven tire wear can lead to poor handling, reduced traction, and premature replacement costs.
Recommended Rotation Interval​
Toyota recommends rotating your tires every 5,000 miles, or during each service visit where tires are inspected.
  • If you regularly drive off-road or tow heavy loads, consider rotating more frequently
  • Always check for abnormal wear patterns during rotation—this may point to alignment or suspension issues
Rotation Pattern​
The 2025 4Runner uses a forward cross rotation pattern for most models:
  • Front tires move directly to the rear on the same side
  • Rear tires move to the front on the opposite side (left rear → right front, right rear → left front)
If your vehicle has directional tires or different tire sizes front/rear, follow manufacturer-specific guidelines or rotate front-to-back only.
Spare Tire Consideration​
  • If the spare tire matches your wheels and tires (full-size), it can be incorporated into the rotation pattern
  • Check pressure and condition of the spare at each rotation, even if not used
TPMS Consideration After Rotation​
If your 4Runner is equipped with a Tire Pressure Warning System (TPWS):
  • Perform wheel position registration using the multi-information display after rotating tires
  • This ensures correct pressure readings are shown per wheel
  • Instructions are on page 546 of the manual
2025 4Runner Tire Rotation Schedule Diagram​
See page 541 of the Owner’s Manual for diagrams of proper tire rotation patterns based on spare configuration.
