TrailHunter Get's Built-In Onboard Air Compressor
If it isn’t installed at the factory/port, Will this be a dealer installed option?
I doubt the dealers would install something like this. Someone will probably make an aftermarket kit though for this spot. Once the aftermarket gets ahold of TrailHunters and starts to pull it apart, they will understand how to fit a similar, likely better, onboard air system in this location. Just need to wait until people start getting their hands on these things.
Sounds cool, but you still have to run a hose to inflate a tire, right? IMO, not worth the money when there are so many great portable inflators out there that you can pack away wherever you want.
Yup you still have to hook up a hose, although I’m sure you can run something similar to the “wifey system” and have pre ran hoses fitted to the wheel wells
It would be a nice accessory to choose if you’re ordering a 4Runner from the factory, but I stand it comes with the one trim.
Agree, I wish they offered it as an option with the Off Road package. Can't wait to see the options the aftermarket will come up with though, exciting times!
They should have put the new brushless ARB in there!
Man that would be sweet. I'll bet ARB will make an aftermarket kit. I love how clean the OEM set up looks. The only issue is that it won't be very accessible if your cargo area is full of camping gear.
Hey All- I really like the look of these...
Perry Parts Front Bump Stops for 2025+ (6th...
I have squealing front brakes on my 2026 TRD...
Hey All- I really like the look of these grille inserts that I found on YotaVerse (see link/pic...
Perry Parts Front Bump Stops for 2025+ (6th Gen) Toyota 4Runner | LC250 / GX550 Bracket Retrofit...
I added 285/70R17 Nitto Terra Grappler G3 tires onto my 6th Gen TRD ORP. I wrapped them around...
We just wrapped up this clean Everest Green 2025 4Runner TRD Off Road Premium build at Mountain...
Drafting up this post as a guide/resource for those who need help with electrical mods, wire...
