- 72
- 21
What Oil to Use on the 6th Generation 4Runner, How Much, and When to Check It
(Reference: 2025 Owner’s Manual, pg. 618–619)
Maintaining proper engine oil levels and using the correct type of oil is critical for engine performance and longevity - especially with the turbocharged T24A-FTS engine found in the 2025 4Runner. There will always be people who swear by different methods, different products, specific brands and the list goes on.
Recommended Oil Type
Toyota recommends Toyota Genuine Motor Oil or an equivalent that meets the following criteria:- Oil Grade: ILSAC GF-6A
- Viscosity: SAE 0W-20
- SAE 0W-20 offers ideal performance for fuel economy, engine protection, and cold-start reliability
- TOYOTA Oil Filter: Oil Filter 90915-YZZN1 Same as 90915-YZZF2
Oil Capacity
Oil capacity depends on whether or not the oil filter is replaced during the change:- With Filter: 5.9 qt. (5.6 L)
- Without Filter: 5.6 qt. (5.3 L)
Oil Change Notes
- After changing the oil, reset the maintenance data in the multi-information display
- Overfilling or using the wrong viscosity can damage the engine
- If you frequently tow, idle for long periods, or drive short distances in cold weather, check your oil more often
2025 4Runner Engine Oil Type and Capacity Diagram
For visual specs and dipstick reference, see pages 618–619 of the Owner’s Manual.
