2025 4Runner Specs: Engine, Drivetrain, Gear Ratio, Dimensions,
Engine Specs
i-FORCE (Gas Option)
  • Type: 2.4L 4-cylinder Turbocharged, DOHC
  • Fuel System: D-4ST Fuel Injection
  • Displacement: 2,393 cc
  • Horsepower: 278 hp @ 6000 rpm
  • Torque: 317 lb-ft @ 1700 rpm
  • Fuel Economy:
    • 2WD (SR5, Sport, Sport Premium): 20 MPG city / 26 MPG highway / 22 MPG combined
    • 4WD (SR5, Sport, Limited, etc.): 19 MPG city / 25 MPG highway / 21 MPG combined
  • Engine Oil Capacity: 5.9 quarts (with filter)
  • Fuel Tank Capacity: 19 gallons
  • Recommended Fuel: Regular Fuel
i-FORCE MAX (Hybrid)
  • Type: 2.4L 4-cylinder Hybrid Turbocharged, DOHC
  • Horsepower: 326 hp @ 6000 rpm
  • Torque: 465 lb-ft @ 1700 rpm
  • Fuel Economy:
    • 4WD (Off-Road, Limited, TRD Pro, Trailhunter): 23 MPG city / 24 MPG highway / 23 MPG combined
Drivetrain / Transmission
  • Drivetrains:
    • 4x2 (Rear-wheel drive)
    • 4x4 (Part-time or Full-time four-wheel drive)
  • Transmission Type:
    • 8-speed Automatic Transmission with the following gear ratios:
      • 1st gear: 4.41
      • 2nd gear: 2.80
      • 3rd gear: 1.95
      • 4th gear: 1.51
      • 5th gear: 1.27
      • 6th gear: 1.00
      • 7th gear: 0.79
      • 8th gear: 0.65
      • Reverse: 3.64
  • Transfer Case (4x4 models):
    • High/low ratio of 1.00:1 / 2.57:1
  • 6th Gen 4Runner Gear Ratio:
    • 3.583
Exterior Dimensions
  • Wheelbase: 112.2 inches
  • Length: 194.9 inches
  • Width: 77.9 inches (79.9 inches for TRD Pro / Trailhunter)
  • Height:
    • SR5: 72.6 inches
    • Sport, Limited, Platinum: 73.1 inches
    • Off-Road / Off-Road Premium: 73.6 inches
    • TRD Pro / Trailhunter: 74 inches (75.5 inches with roof rack)
Interior Dimensions
  • Seating Capacity: 5 (7 seats available on i-FORCE SR5 and Limited trims)
  • Interior Space:
    • Shoulder Room (Front/Rear): 58.0 in / 57.8 in
    • Hip Room (Front/Rear): 55.2 in / 56.1 in
    • Headroom (Front/Rear): TBA
    • Legroom (Front/Rear): TBA
    • Cargo Capacity: N/A (varies by configuration)
Brakes squealing like a banshee in reverse...
Rubicon Portal Party - 74Weld Gen2 Portal...
Hello, I just picked up part number PT 228-89445 which is the suggested part number on all sites...
We finally got the 6th Gen 4Runner out on some tighter NorCal trails for its first proper...
Rubicon Portal Party - 74Weld Gen2 Portal Axles Tested... Proven We've been planning this...
For anyone looking for a great Mud Terrain on wet surface roads that also performs incredibly...
Brakes squealing like a banshee in reverse. Took to dealership with 3800 miles. TSB-0046-25...
I installed the OTT tune on my 4Runner Hybrid as my very first mod at just 80 miles, and...
I saw a few other discussions regarding the wireless charging pad that comes in some of the trim...
TRD Pro Grille Swap on 6th Gen 4Runner - Not Fun, but worth the upgrade... The TRD Pro grille...
What do you all want to see for the new TRD Pro color? I hope whatever it is, it isn't another...
The all-new TRD Pro color for 2026 is here—and it looks amazing on the 4Runner. Meet Wave Maker...
