2025 (6th Gen) 4Runner Overheating Guide
What to Do If Your Engine Temperature Rises on the 6th Gen 4Runner?
(Reference: 2025 Owner’s Manual, pg. 612)
Overheating can occur during extreme driving conditions, long hill climbs, stop-and-go traffic in high temperatures, or if there’s a mechanical issue like low coolant. If you see the temperature gauge spike or the “Engine Coolant Temp High” warning appears, follow these steps immediately.
Step-by-Step Response​
  1. Stop the vehicle safely as soon as possible
    Pull over and shift into Park. Keep the engine idling if safe to do so.
  2. Turn off the air conditioning
    Reduce engine load by turning off A/C and switching the blower to the highest heat setting.
  3. Check the engine compartment
    If you see steam, do not open the hood until it fully dissipates.
  4. After the engine cools
    Open the hood and visually inspect for coolant leaks or belt issues. Check the coolant level in the reservoir.
    Never open the radiator cap when the engine is hot.
  5. Add coolant if needed
    If the coolant level is low and no leak is obvious, top it off with engine coolant or water in an emergency.
    Restart the engine and monitor the temperature gauge.
  6. If the warning light stays on or coolant drains again
    Turn the engine off and contact a Toyota dealer or roadside assistance.
Preventive Notes​
  • Regularly check coolant level and inspect for leaks
  • Use only Toyota Super Long Life Coolant or equivalent
  • Watch for early signs of overheating: weak heater output, engine knock, reduced power
2025 4Runner Engine Overheating Troubleshooting Diagram
Refer to page 612 of the Owner’s Manual for overheating warning indicators, step-by-step instructions, and coolant system precautions.
Anyone happen to know if the Accessory Prewire...
Anyone happen to know if the Accessory Prewire option can be installed on a 26 4 Runner after...
