2025 Toyota 4Runner: Curb Weight, GVWR, and Towing Capacity
2025 Toyota 4Runner: Weight and Towing Specifications
Towing Capacity
  • Maximum Towing Weight: 6,000 lbs (Per SAE J2807 methodology)
Weight Data
  • Curb Weight (lbs.):
    • 2WD SR5: 4,455 lbs
    • 2WD TRD Sport: 4,610 lbs
    • 2WD Limited: 4,730 lbs
    • 4WD SR5: 4,685 lbs
    • 4WD TRD Sport: 4,850 lbs
    • 4WD Off-Road: 4,850 lbs
    • 4WD Limited: 4,970 lbs
    • 4WD Off-Road Premium: 5,225 lbs
    • 4WD TRD Pro: 5,370 lbs
    • 4WD Trailhunter: 5,455 lbs
    • 4WD Platinum: 5,500 lbs
    • 4WD i-FORCE MAX: 5,390 lbs
  • Gross Vehicle Weight Rating (GVWR) (lbs.):
    • 2WD SR5: 6,005 lbs
    • 2WD TRD Sport: 6,020 lbs
    • 2WD Limited: 6,130 lbs
    • 4WD SR5: 6,075 lbs
    • 4WD TRD Sport: 6,395 lbs
    • 4WD Off-Road: 6,240 lbs
    • 4WD Limited: 6,395 lbs
    • 4WD Off-Road Premium: 6,505 lbs
    • 4WD TRD Pro: 6,505 lbs
    • 4WD Trailhunter: 6,505 lbs
    • 4WD Platinum: 6,505 lbs
    • 4WD i-FORCE MAX: 6,505 lbs
Fuel Capacity
  • Fuel Tank Capacity: 19 gallons
Engine Oil Capacity
  • Engine Oil Capacity (with filter): 5.9 quarts
So there's no difference in towing capacity between the i-FORCE and i-FORCE MAX? I understand it's probably all based on chassis and not power/torque specs but that's a bummer. Toyota hyped up the i-FORCE MAX for towing and torque but still the same towing capacity on the standard i-FORCE. Nice.
1. Is the fuel tank really the same size in both gas and hybrid models? I had expected that the fuel tank would be smaller in the hybrid. If both have the same size tank, the driving range for a tank of gas in the hybrid should be greater. I haven't seen anything with projected driving ranges for the different engines.
2. I'm also curious what creates the extra 375 lbs in the ORP vs. the OR? That's a fairly substantial difference. And the GVWR for the two vehicles is not commensurate -- the ORP only has 265 lbs more than OR in GVWR.
3. This chart seems to be incomplete -- it does not show comparable curb weight and GVWR for gas and hybrid versions of trims where both options are offered.
Hi Guys I would appreciate your input here before I open up a can of worms for Toyota. Last...
