2025 (6th Gen) 4Runner Brake Fluid Replacement Schedule
When to Check, What to Use, and Safety Tips
(Reference: 2025 Owner’s Manual, pg. 535–536)
Brake fluid is a critical part of your 4Runner’s braking system. Over time, it can absorb moisture from the air, reducing braking effectiveness and increasing the risk of brake fade—especially under heavy use.
Recommended Brake Fluid Type​
Toyota recommends the following fluid types:
Use only newly opened brake fluid containers, as fluid can absorb moisture once exposed to air.
Brake Fluid Inspection Schedule​
  • Check the fluid level regularly, especially before long trips or off-road use
  • Toyota recommends replacing the brake fluid every 2 years, regardless of mileage
  • For severe-duty driving (frequent towing, mountain descents, or dusty/dirty environments), inspect more frequently
How to Check the Fluid Level​
  1. Locate the brake fluid reservoir on the driver side of the engine bay
  2. Check that fluid is between the “MAX” and “MIN” lines on the tank
  3. Do not overfill; if low, add fluid slowly and carefully
  4. Always use a clean funnel dedicated only to brake fluid
Safety Notes​
  • Brake fluid is corrosive to paint and harmful to skin and eyes—wear gloves and wipe any spills immediately
  • Overfilled or low levels may indicate pad wear or leaks
  • If frequent refills are needed, consult your dealer for inspection
  • Always ensure the reservoir cap is secure after checking or adding fluid
2025 4Runner Brake Fluid Diagram​
Refer to pages 535–536 in the Owner’s Manual for a visual reference of the reservoir and fluid level markings.
Funny story, but I actually stumbled upon this...
Anyone ever bought anything from these guys or...
How is everyone thinking about turbo care and...
Hey All- I really like the look of these grille inserts that I found on YotaVerse (see link/pic...
Funny story, but I actually stumbled upon this product before I even knew that this cubby even...
Anyone ever bought anything from these guys or know if they are legit...
Perry Parts Front Bump Stops for 2025+ (6th Gen) Toyota 4Runner | LC250 / GX550 Bracket Retrofit...
My 2025 TRD offroad mods so far include: Wescott full roof rack Cali Raised sliders...
How is everyone thinking about turbo care and maintenance on the 6th gen. Besides regular oil...
Good news for anyone planning a front locker upgrade on the 6th Gen 4Runner. Eaton ELocker front...
