2025 (6th Gen) 4Runner Light Bulb Replacement Guide
DIY Bulbs, LED Info, and What to Leave to the Dealer
(Reference: 2025 Owner’s Manual, pg. 563–565)
The 2025 4Runner includes a mix of standard replaceable bulbs and sealed LED units. Toyota allows some exterior bulb replacements to be done by owners but recommends dealer service for most interior and LED-equipped fixtures.
Owner-Replaceable Bulbs​
The following can be replaced by the owner with basic tools:
  • Side marker lights
  • Side turn signal lights
  • Tail lights
  • Stop lights
  • Back-up lights
  • Rear turn signal lights
  • License plate lights
  • High-mounted stoplight
  • Trailer hitch light
Always verify the wattage on page 623 and match the part number before replacing.
Front Turn Signal / Parking Lights (Bulb Type)​
Only applicable if your 4Runner came with non-LED housings:
  1. Remove the 5 push clips and the air cleaner inlet (passenger side only)
  2. Turn the bulb base counterclockwise
  3. Pull out and replace the bulb
  4. Reinstall in reverse order
Important Warnings​
  • Always turn off the lights and let them cool before handling
  • Do not touch the glass part of the bulb—use a clean, dry cloth
  • Make sure bulbs are fully seated and locked to prevent moisture or fire risk
  • LED lights are non-serviceable; take your vehicle to a Toyota dealer if they fail
  • Never use a bulb with a different wattage or substitute with non-Toyota parts
Signs of Bulb Failure​
  • Flickering or dim lights
  • Warning light on the dash
  • Lens condensation or moisture inside the housing
  • No illumination when switched on
2025 4Runner Light Bulb Replacement Diagram​
See pages 563–565 for the DIY replacement overview and location diagrams.
Image filename:
Hello, newbie here. Unable to find a thread on...
Yoooo. Just confirmed that this glitch works...
After a long-winded Facebook Post the other day with 100+ Comments, there seems to be an...
Had my 2 front windows ceramic tinted to match the rest of the windows.
Hello, newbie here. Unable to find a thread on my stupid question - do i get annoying panel...
Hey does anyone know if these are in the works? I have looked all over online and no one makes...
Yoooo. Just confirmed that this glitch works and it will be honored! 50% off a full set of the...
Hey 6G family! We recently launched our latest round of sales... 50% off the new ARB floor mat...
Recently updated the wheels and tires on my TRD OFF-ROAD Wheels - Niche Vice : 20x9 Tires -...
