OEM Wheel Sizes & Specs: 2025+ (6th Gen) Toyota 4Runner
This post will cover factory wheel sizes, lug torque specs, tire sizes, and other wheel-related data for the 6th Gen 4Runner. Whether you're planning a tire upgrade or just need OEM reference specs, this thread has everything in one place. We are still working on detailed specs like offset, backspace, hub bore, and more. We will keep the thread updated as more specs start to come out on dealer lots.
Wheels, Tires, Bolt Pattern, Lug Nut Size, Hub Bore
  • SR5: 17" inch dark gray metallic alloy wheels
  • TRD Sport (Premium): 20" inch machine finished alloy wheels, 31.5" Yokohama Geolandar A/T G015 Tires (265/55R20)
  • TRD Off-Road (Premium): 18" inch machine finished alloy wheels, 32.6" Michelin All-Terrain tires (265/70R18)
  • Limited: 20" inch machine finished alloy wheels, 31.5" Dunlop Grandtrek AT20 tires (265/55R20)
  • Platinum: 20" inch black alloy wheels, 31.5" Dunlop Grandtrek AT20 tires (265/55R20)
  • Trailhunter: 18" inch flat bronze finished alloy wheels, 33" inch Toyo Open Country A/T III All-Terrain tires (265/70R18)
  • TRD Pro: 18" inch flat black finished alloy wheels, 33" inch Toyo Open Country A/T III All-Terrain tires (265/70R18)
  • Bolt Pattern: 6-139.7
  • Lug Nut Size: 14x1.5
  • Hub Bore: 95.1
Wheel Sizes by Trim
Toyota lists multiple wheel sizes for the 6th Gen, depending on trim:
17-Inch (Type B)
  • Tire Size: 245/70R17 110T
  • Wheel Size: 17 x 7J
  • Spare: 17 x 7J
  • Torque Spec: 97 ft-lb (131 Nm)
18-Inch (Type A and B)
  • Type A:
    • Tire Size: 245/70R18 110H
    • Wheel Size: 18 x 7.5J
  • Type B:
    • Tire Size: 265/70R18 116T
  • Spare: 18 x 7.5J
20-Inch (Type A and B)
  • Type A:
    • Tire Size: 265/55R20 113V
    • Wheel Size: 20 x 8J
  • Type B:
    • Spare: 245/75R17 112S
    • Wheels: 20 x 8J (main), 17 x 7J (spare)
    • Torque Spec (steel wheels): 154 ft-lb (209 Nm)
Tire Pressure Specs
  • All tires: 33 psi (cold)
  • Spare (temporary use): Up to 60 psi depending on size
Other Wheel & Tire Specs
  • Bolt Pattern (PCD): Not listed in the Owner’s Manual, but expected to remain 6x139.7 (same as 5th Gen)
  • Hub Bore: Not explicitly listed, but likely 106 mm like the 5th Gen
  • Offset & Backspacing: Not specified in the Owner’s Manual – must be measured or referenced from wheel manufacturer specs
Lug Nut Torque
  • Most trims: 97 ft-lb
  • Steel wheels (Type B spare): 154 ft-lb
What Does The J Mean?​
The “J” in 17 × 7J refers to the wheel bead seat profile—specifically, the shape of the inner lip of the wheel where the tire bead sits.
  • 17 = Wheel diameter in inches
  • 7 = Wheel width in inches (measured inside the bead seat)
  • J = Bead seat design / flange shape
  • The letter “J” is the most common flange profile for passenger vehicles and light trucks (including Toyota 4Runners).
  • It defines how the inner lip is shaped to hold the tire bead.
  • Other letters like “JJ,” “K,” or “H” exist, but “J” is standard for off-road and SUV wheels.
You don’t really need to worry about it unless you’re trying to mount tires on non-standard rims or doing something niche with fitment. For normal off-road builds or tire upgrades, just know that “J” is correct and compatible with typical all-terrain and mud-terrain tires.
The OEM wheel on 2025 TRD ORP is +55mm offset. If I put the 2025 TRD Pro wheel with 20mm offset on this vehicle, I assume it will fit OK with OEM sized tires (265/70R18)? Both wheels are same width; only difference is less offset.
Hoo boy, now I'm really confused. I've been looking at wheel specs on different sites and they're all over the place for the same TRD Pro wheel. For example:
  • OEMPartsOnline says 2025 Toyota TRD Pro 18-in wheels are 8-in wide with +45mm offset; a dealer's site agrees, showing the identical page
  • Rave Offroad says these wheels are 8.5-in wide with +20mm offset
  • The original post (above) says these are 7.5-in wide without specifying offset, while another 6G forum agrees on width and offset is +20mm
  • Amazon lists OEM wheels as 8.5-in wide with +20mm offset, agreeing with Rave Offroad
  • A post with pictures on another forum agrees with Amazon and Rave Offroad
So I'm guessing that the real specs are: 8.5-in wide with +20mm offset. How can it be this confusing?
@sscarter - yeah, the TRD Pro wheels are a much more aggressive offset with +20mm, while most of the other trims like the TRD OR and Sport are +55mm offset.
Here are a few shots of the markings on the inside of my TRD OR wheels showing +55mm offset:
Usually, anything below a 0mm offset is going to be way too aggressive. The trailhunters and pros are on a +25 offset. Other models (TRD Offroad, Sport, Limited, etc. all have all+55mm offset. If you want more stance/poke, you’ll need a smaller tire or to remove mudflaps, crash plates, and pin the fender well back. I've seen the 285/70/18 Nitto Ridge grapplers (33.9") tire fit with no lift or rub, but on a stock offset of +25. These 4Runners are really designed around a max of +25mm offset with 285/70/18 tires. If you want to go with a 17" tire, then look at a 285/75/17 with +25mm wheels and you will be fine.
Hi Guys I would appreciate your input here before I open up a can of worms for Toyota. Last...
