2025 (6th Gen) 4Runner Fuse Box Location & Replacement Steps
How to Locate, Check, and Replace Fuses on the 6th Generation 4Runner
(Reference: 2025 Owner’s Manual, pg. 560–562)
If any of your 4Runner’s electrical components stop working—such as power outlets, lights, or infotainment features—it may be due to a blown fuse. Here’s how to locate and inspect the fuse boxes on your 2025 4Runner.
Fuse Box Locations​
There are three main fuse box locations:
  • Engine Compartment – Type A
  • Engine Compartment – Type B
  • Driver-Side Instrument Panel (Interior)
Use the tabs to lift the cover on the engine compartment fuse boxes. On the interior panel, you’ll need to remove the footwell light connector (if equipped), then remove the panel cover.
How to Check & Replace a Fuse​
  1. Turn the engine switch OFF
  2. Open the appropriate fuse box cover
  3. Use the provided fuse puller to remove the suspect fuse
  4. Inspect the metal strip inside:
    • If broken: The fuse is blown
    • If intact: The fuse is good
  5. Replace with a new fuse of the same amperage rating
  6. Reinstall the lid securely
Only Type A fuses can be pulled using the included tool.
Fuse Types​
There are four fuse types:
  • Type A & B: Mini blade-type (owner replaceable)
  • Type C & D: Special fuses (dealer service only)
Safety Precautions​
  • Never use a fuse with a higher amp rating than specified
  • Don’t bypass fuses using wire or other objects
  • If the new fuse blows again, have the vehicle inspected immediately
  • Always determine the cause of the overload before replacing the fuse
2025 4Runner Fuse Box Location and Replacement Diagram​
See pages 560–562 for step-by-step visuals and fuse layout identification.
Here is a look at the interior fuse box on the 6th Gen 4Runner.
The fuse box is no longer located in the driver's side, it's now on the passenger side under the glove box and airbag.
Just wanted to share a few photos of the fuse box location and the actual fuse box cover showing all the fuse names.
To access the fuse box, there is a cover just below the airbag. There are four tabs holding the cover on. To remove the cover, pull down on the outside corner and then push in on the clip to release the tab. Repeat for each of the tabs and the cover will come off.
Here is a look at the tabs.
Here is a look at the fuse box on the passenger side, under the glove box and airbag.
Here is a detailed look at the fuse box cover.
Here is a more detailed vertical photo of the fuse box cover so you can open it on your phone.
@Trail4R The two pictures of the engine compartment fuse boxes, seem to be reversed. At least in my vehicle the one shown here as being on the passenger side, is in my vehicle on the driver side and vice versa.
I'll check the fuse boxes again and confirm my titles above both photos. Thanks for calling it out.
Is the SUB BATT fuse used between the start up battery and the DC-DC step down converter? If not, which fuse might be doing that? My goal is to determine how much current can be drawn from that converter.
Thanks a lot.
Hi I just got my 2025 4Runner iforcemax hybrid and want to install the Wolfbox mirror. I want to use the passenger side fuse box. Which fuse should I use for the constant power and the ACC?
Thanks.
Which fuse should I use for constant power and ACC to install the Wolfbox TriPro bumber mirror?
@Xraytekca - you're trying to tap for a radar detector? The ignition fuse would probably work. Are you trying to run the lead into the cabin or engine bay?
Yes sir I’m gonna hardwire the radar detector today. I just don’t know which fuse to tap into.
Did they install this mornin. Use the third from the bottom which was blank and that’s the spot I used to ground radar detector turns on works perfect
I spent time with 2026 4Runner Platinum...
Hey 4runner gang looking for some opinions for...
Hey everyone, stoked to be here! We’re...
I spent time with 2026 4Runner Platinum yesterday, and I wonder if it's the best of all the...
Hey everyone, stoked to be here! We’re IRONMAN 4X4, and at our core, we’re enthusiasts who care...
