OEM Wheel Sizes & Specs: 2025+ (6th Gen) Toyota 4Runner
This post will cover factory wheel sizes, lug torque specs, tire sizes, and other wheel-related data for the 6th Gen 4Runner. Whether you're planning a tire upgrade or just need OEM reference specs, this thread has everything in one place. We are still working on detailed specs like offset, backspace, hub bore, and more. We will keep the thread updated as more specs start to come out on dealer lots.
Wheel Sizes by Trim
Toyota lists multiple wheel sizes for the 6th Gen, depending on trim:
17-Inch (Type B)
  • Tire Size: 245/70R17 110T
  • Wheel Size: 17 x 7J
  • Spare: 17 x 7J
  • Torque Spec: 97 ft-lb (131 Nm)
18-Inch (Type A and B)
  • Type A:
    • Tire Size: 245/70R18 110H
    • Wheel Size: 18 x 7.5J
  • Type B:
    • Tire Size: 265/70R18 116T
  • Spare: 18 x 7.5J
20-Inch (Type A and B)
  • Type A:
    • Tire Size: 265/55R20 113V
    • Wheel Size: 20 x 8J
  • Type B:
    • Spare: 245/75R17 112S
    • Wheels: 20 x 8J (main), 17 x 7J (spare)
    • Torque Spec (steel wheels): 154 ft-lb (209 Nm)
Tire Pressure Specs
  • All tires: 33 psi (cold)
  • Spare (temporary use): Up to 60 psi depending on size
Other Wheel & Tire Specs
  • Bolt Pattern (PCD): Not listed in the Owner’s Manual, but expected to remain 6x139.7 (same as 5th Gen)
  • Hub Bore: Not explicitly listed, but likely 106 mm like the 5th Gen
  • Offset & Backspacing: Not specified in the Owner’s Manual – must be measured or referenced from wheel manufacturer specs
Lug Nut Torque
  • Most trims: 97 ft-lb
  • Steel wheels (Type B spare): 154 ft-lb
What Does The J Mean?​
The “J” in 17 × 7J refers to the wheel bead seat profile—specifically, the shape of the inner lip of the wheel where the tire bead sits.
  • 17 = Wheel diameter in inches
  • 7 = Wheel width in inches (measured inside the bead seat)
  • J = Bead seat design / flange shape
  • The letter “J” is the most common flange profile for passenger vehicles and light trucks (including Toyota 4Runners).
  • It defines how the inner lip is shaped to hold the tire bead.
  • Other letters like “JJ,” “K,” or “H” exist, but “J” is standard for off-road and SUV wheels.
You don’t really need to worry about it unless you’re trying to mount tires on non-standard rims or doing something niche with fitment. For normal off-road builds or tire upgrades, just know that “J” is correct and compatible with typical all-terrain and mud-terrain tires.
Featured
I think this is the 2025 4Runner Platinum in...
Hey all! Underground Sport Premium. 20' Nitto Ridge Grappler tires. Pretty much everything is...
I know the pro and trailhunter have wider fenders, but are the Off-road trims wider than the...
Yes they sure do. I have these laying around from my old fourth GEN and I decided to give them a...
After mocking up a few other wraps and livery concepts, I started to play around with the Turbo...
Has anyone encountered this yet with your new 4Runner? It’s starting to get humid here in FL and...
When at the New York Autoshow, I had the unique opportunity to have both a 4R Limited and LC250...
Seeing if anyone with other models have pre drilled threads in their frame for aftermarket rock...
Back at it with some wrap inspiration on the 6th Gen 4Runner. We have everything from multi-cam...
Take a look at some of these livery mockups inspired by the 1st Gen 4Runner Turbo graphics with...
Anyone install the readylift or peak performance leveling kits yet? I'm trying to decide on...
Took a little drive to Muleshoe Bend to get some dirt on the tires and see the bluebonnets. Love...
