- Aug 19, 2025
- 30
- 10
Best Budget Lift Kits for the 2025+ 4Runner
When picking an entry-level lift kit for the 6th Gen 4Runner, the first step is figuring out your goals. Do you want it to sit a little taller just for looks and daily driving? Or are you planning to take it off-road and need the geometry correction that helps with long-term suspension performance?
Budget kits often use preload collars or spacers so you can reuse your factory shocks. The trade-off is they don’t always correct geometry. Kits with upper control arms (UCAs) give you better alignment, better ball joint angles, and longer-term durability.
Height also matters. A modest lift of 2–2.5" keeps driving behavior closer to stock, while going 3" or more usually means adding diff drops, bump stop changes, or extra geometry parts. Knowing your budget and how much install effort you’re willing to put in helps narrow your options.
Peak Suspension – 2-Piece Summit Kit 2.25"
Peak’s Summit Kit is a great option that combines spacers and spring seat adapters while including UCAs for geometry correction. It’s one of the few that balances height with stability out of the box.
- 2.25" front lift via top spacer + spring seat adapter
- Includes tubular UCAs to maintain correct caster and allow more droop
- Rear lift options of 1" or 2" spring spacers; direct bolt-on
Westcott Designs – Preload Collar Lift Kit
Westcott was one of the first to release a dedicated 6th Gen 4Runner lift, and this preload collar kit is designed to reuse your factory shocks while giving the truck a subtle but noticeable lift. It’s a clean setup that keeps ride quality close to stock.
- 2.5" front, 1" rear (varies by trim)
- Preload collar design with black anodized finish
- No UCA required
Rough Country – 2.5" Leveling Lift Kit (72800)
Rough Country’s kit is designed for people who want a simple lift without too much fuss. It raises both front and rear by about 2.5" using spacers, maintaining a balanced look.
- Spacer-based front + rear 2.5" lift
- Uses factory shocks, no major modifications
- Budget-conscious install for everyday use
ReadyLIFT – 2.5" SST Lift Kit
ReadyLIFT’s SST kit gives you a more entry-level lift with basic components. It’s a solid choice to just get a slightly better-looking stance.
- 2.5" front, -1.5–2" rear lift
- Comes with bump stop hardware
Torq Engineering – 3" Lift Kit
Torq’s kit pushes the lift number up to 3", giving the 4Runner a more aggressive height. It’s a straightforward package designed for the 2025+ chassis.
- 3" of lift
- Spacer-based design with simpler install
- Built specifically for 6G 4Runner geometry
