285/75R17 Toyo R/T Trail Tires on Method 703 Matte Black +35 Offset
8RunnerOffRoad
Vendor/Sponsor
Portland, OR
8runneroffroad.com
Charles came into 8Runner Off-Road with a 2025 4Runner TRD Sport and a clear goal: fit larger tires on clean, aggressive wheels without going overboard. The result? A dialed-in setup that balances performance, clearance, and aesthetics.
2025 4Runner TRD Sport build:
  • Westcott Designs Lift Kit (6th Gen 4Runner)
  • Toyo Open Country R/T Trail Tires – 285/75R17
  • Method Race Wheels – 703 Black +35 Offset (x4)
  • Method Race Lugs
  • OEM TPMS Sensor (x1)
We mounted a set of 285/75R17 Toyo Open Country R/T Trail tires on Method 703 wheels in matte black with a +35 offset. This tire and wheel combo delivers excellent road manners, solid off-road grip, and a slightly taller profile that fills out the 6th Gen’s wheel wells just right. The +35 offset keeps the stance tucked in enough to avoid unnecessary trimming, while still giving it a more planted, aggressive look.
To support the new tire size, we installed a Westcott Designs lift kit, which provides the clearance needed without dramatically altering factory geometry. A full alignment followed to get everything tracking properly, and we added new TPMS sensors and Method Race lugs to wrap up the install.
If you're planning a similar setup on your 6th Gen 4Runner, the +35 offset on the Method 703s is a solid choice, enough clearance for 285s without excessive poke, and perfect for daily driving or moderate trails.
Reach out to 8Runner Off-Road in Tigard, OR, if you're ready to upgrade.
8Runner Off-Road & Overland Outfitters
10160 Southwest Nimbus Avenue, Suite F2
Tigard, OR 97223
Phone: (503) 352-4629
Email: nathan@8runneroffroad.com
Website: www.8runneroffroad.com
Anyone happen to know if the Accessory Prewire...
Anyone happen to know if the Accessory Prewire option can be installed on a 26 4 Runner after...
