- Aug 19, 2025
- 60
- 40
The Top 7 Bolt-On Rock Sliders for the 2025+ 4Runner, Different Options for Kick-outs, Top-Plates, and More.
I’m looking at rock slider options for the new 6th Gen 4Runner and wanted to put everything I’ve found in one place. Sliders are on the top of my list at the moment. A lot of companies are finally starting to make them, so here are some of the brands I’m considering.Things to Note
When shopping for rock sliders, keep in mind that some models may not come with threaded holes for mounting. In those cases, you might need additional hardware or extra steps to get them installed properly. You can read more about this in the thread here: https://6thgen4runner.com/threads/s...on-your-frame-rail-to-mount-rock-sliders.674/HREW vs DOM
DOM is stronger, holds its shape better, and is what you want if you’re hitting real rocks. HREW is cheaper and fine for light trail use, but it will bend more easily under heavy impacts.
Angled vs Step
Flat or step sliders make it easier to get in and out, especially if your truck is lifted. Angled sliders tuck up higher for better clearance and rocker panel protection, but they’re harder to use as an actual step.
Cali Raised LED
Cali Raised offers a step edition slider for the 6th Gen that you can get with or without a kick-out. They even showed one holding the weight of the truck on Instagram, so strength doesn’t seem to be a question. I have ran their skid plates in the past and planning on running their stealth bumper in the future and so far everything they make is 10/10,
• DOM tubing construction
• Kick-out or straight options
• Raw, powder coat, or bedliner finishes
Check it out online: Cali Raised Rock Sliders
Starts at $889.99
Westcott Designs
Westcott lets you customize almost every detail, from the type of steel to the welding and angle. That level of choice is rare and makes them stand out. These options work for everyone from major rock crawlers to the weekend warriors, so it's a good idea to take a look at these and mess around with the options to fit your rig.
• DOM or HREW steel
• MIG or TIG welded
• 0° or 20° angle with or without top plates
Check it out online: Westcott Designs Rock Sliders
Starts at $999.00
CBI Offroad
CBI has a long track record, and its sliders are built to take a beating. They double as jacking points, which is something I’d prefer not to but would actually use on the trail. Strong enough to hold the entire weight of the vehicle, these know how to take a hit.
See a more in-depth review on these rock sliders here: https://6thgen4runner.com/threads/cbi-offroad-overland-rock-sliders-w-dom-tubing.433/
• DOM steel tubing
• Powder coat or bare finish
• Frame-mounted design
Check it out online: CBI Offroad Rock Sliders
Starts at $1,300.00
Dissent Offroad
Dissent built theirs to work as both a slider and a fully functional step, which feels practical if your 4Runner is sitting taller. Dissent is not new to the game by any means, and that is clear here with a heavy-duty design built for real use. These guys are coming out with some insane parts for the 4Runner so I am keeping a close eye on new releases here.
You can see more of the dissent build here
• Steel construction
• Integrated step surface
• Designed for the 6th Gen 4Runner
Check it out online: Dissent Offroad Rock Sliders
Starts at $1,795.00
RCI Metalworks
RCI has been doing armor for a while, and their 6th Gen sliders carry that same tough, no-nonsense feel. If you are looking for a solid, affordable option this should be top of your list.
• Finish options available
Check it out online: RCI Rock Sliders
Starts at $763.99
NYTOP
NYTOP actually posts stress test results, which is something you don’t see often. They’re heavy-duty and one of the best-looking options. NYTOPs offroad parts have been absolutely incredible love seeing everything they are doing and hope to keep seeing more soon.
• Tested under heavy loads
• Tailored to the 6th Gen body lines
Check it out online: NYTOP Rock Sliders
Starts at $1,399.99
Restless Offroad
Restless puts extra detail into theirs with gussets, brackets, and solid mounting plates. They look like a heavy-duty option right out of the box, and offer light mounting to really get the most out of it.
• 1.75-inch DOM tubing
• Gusseted with thick mounting plates
• Includes rock light brackets and Grade 8 hardware
Check it out online: Restless Offroad Rock Sliders
Starts at $799.99
Final thoughts
This comes down to what your rig is going to be used for. The step editions are convenient for daily use and passengers, but they can stick out more on the trail. DOM tubing versus regular steel is another thing to weigh in DOM costs more but it’s proven to take hits without bending. At the end of the day, all of these will protect the rocker panels, it just depends on how much strength, finish quality, and convenience you want for your rig.If I missed any or if there are any coming out that I should be aware of let me know!
