- 69
- 19
2025 is the first model year Toyota has ever offered a factory-integrated trailer brake controller on a 4Runner! Previously, 4Runner owners had to install aftermarket brake controllers like the one from Red Arc (https://www.redarcelectronics.com/us/toyota/4runner) to tow safely with electric trailer brakes. The addition of a built-in, gain-adjustable brake controller in 2025 brings the 4Runner is a big deal for anyone towing off-road trailers, campers, or utility loads.
Setup, Calibration, and Operation
(Reference: 2025 Owner’s Manual, pg. 437–444)
The 2025 4Runner offers a built-in Trailer Backup Guide and a Toyota Genuine Trailer Brake Controller to help make towing safer and easier. Here's how to get started with both systems
It works with most electric and electric-over-hydraulic trailer brakes (up to 3 axles), but not with hydraulic surge brakes.
Key Features:
Refer to the Owner’s Manual (pages 437–444) for switch layout, calibration visuals, and gain setting instructions.
Trailer Brake Controller Overview
The trailer brake controller manages trailer braking through the 7-pin wiring harness and includes a manual brake slider and gain adjustment.It works with most electric and electric-over-hydraulic trailer brakes (up to 3 axles), but not with hydraulic surge brakes.
Key Features:
- Gain range: 0.0 to 10.0 (adjusted in 0.5 increments)
- Gain settings control how strongly the trailer brakes are applied
- Manual brake slider engages only the trailer brakes for checking or control
- Brake output is displayed on the multi-information display
- Start with gain at 5.0
- Drive 20–25 mph on level ground
- Use the manual slider to apply brakes
- Increase or decrease gain until trailer wheels are just below lock-up
- Recheck after load or road conditions change
Trailer Backup Guide Overview
Trailer Backup Guide helps you reverse with a trailer using either.- Guidance Mode: Displays a trailer path based on steering angle
- Straight Path Assist: Automatically controls steering to keep the trailer backing in a straight line
- Add trailer via "Trailer Settings" in the multi-information display
- Press the Trailer Backup Guide switch to turn the system ON
- Complete initial trailer calibration by following on-screen instructions
- Shift into Reverse to enable Guidance Mode
- Tap the multimedia screen to activate Straight Path Assist
Operation Tips & Limitations
- Keep the rear camera clean and unobstructed
- Avoid sharp trailer tongue changes post-calibration without re-calibrating
- The system disables above ~5 mph or if the camera loses trailer tracking
- Straight Path Assist can be overridden with steering input
- Always monitor your surroundings; the system does not handle braking
Safety Warnings
- Only use with compatible trailer types and within operating limits
- Check trailer brake condition before towing
- Never rely solely on automated guidance—driver remains responsible for control
- Keep the hitch light and rear camera properly aligned for optimal performance
2025 4Runner Trailer Backup Guide and Brake Controller Diagram
