Windshield Washer Reservoir Relocation 6th Gen 4Runner
While installing the Dissent high clearance front bumper, I decided to relocate my windshield washer reservoir. Dissent had a spare reservoir lying around, so we made it work. The factory washer reservoir hangs down very low, and with a high clearance bumper, is exposed to not only the rocks/damage, but is also extremely distracting visually, hanging under the bumper.
Start by draining the washer fluid out by removing the pump. Disconnect the pump connector harness, the fill sensor harness, and all the lines.
The factory washer reservoir housing can be removed via three (3) 10mm bolts. Two are easy to reach, and the third is behind the washer reservoir. Once the front two are removed, you have to swivel the washer reservoir down, and the third can be reached with a long extension.
Once the reservoir has been removed and all the lines/harnesses have been disconnected, you can fit the new washer reservoir.
To fit the OEM pump into the new washer housing, you may need to take a heat gun to the washer housing and mold the pump into the plastic.
I'm going to be getting a new 2025 4Runner...
While installing the Dissent high clearance...
I'm going to be getting a new 2025 4Runner next month (my wife already has a 2025 TRD Pro...
While installing the Dissent high clearance front bumper, I decided to relocate my windshield...
Incredibly stoked to share this one with you guys. The first drawer system on the market for the...
CBI Offroad just put together one of the most insane 6th-gen 4Runners we’ve seen yet, and it...
Okay guys, the first high clearance “Mustache Delete” bumper has arrived. Although it's not 100%...
A couple photos of Dissents backup camera relocation kit for the 6th Gen. If you need a...
I recently bought my 4Runner TRD PRO in Oklahoma and need to register it in Texas. The dealer...
After driving my buddy's TRD Pro the other day, I really liked some of the accents in the...
Posting this so we can stack up some Black 6Gs for build inspiration. This color might be...
Dissent Off-Road just launched their Low Profile Front Bumper for the 2025+ 6th Gen 4Runner...
