- Aug 19, 2025
- 56
- 26
Top Upper Control Arm Options for the 2025+ 4Runner
If you’re planning to lift your new 4Runner, upper control arms are one of those upgrades you’ll end up thinking about sooner or later. The stock arms do fine at factory height, but once you crank things up a couple of inches, alignment gets tricky and steering can start to feel a little off. A good set of UCAs fixes all that and adds strength, more travel, and better control on rough roads.Why Upgrade Your Upper Control Arms
- Keeps your alignment and caster dialed in after a lift
- Smoother steering and more confidence on and off the trail
- Stronger joints and materials that can actually handle hard use
Dirt King Billet UCAs
High-end upper control arms built for strength and precise alignment correction on lifted 4Runner.
- Rebuildable, USA-made construction
- Precision-welded 4130 chromoly tubing
Peak Suspension Tubular UCAs
Tubular chromoly design with sealed ball joints. A solid balance of strength, price, and everyday drivability.
- Chromoly tubing with powder coat finish
- Sealed ball joints, low maintenance
- Improves alignment on lifted trucks
JBA High Caster UCAs
Tubular steel arms with high-caster geometry that simplify alignment after a lift. Ball-joint design keeps maintenance low.
- Tubular steel construction
- Fits 1–3.5" lifts
Ironman 4x4 Chromoly UCAs
Durable chromoly arms with sealed bushings and ball joints. Great match for daily drivers or trail rigs using 2–3" lifts.
- Chromoly steel tubing
- Sealed, low-maintenance joints
Total Chaos UCAs
4130 chromoly tubular arms built specifically for the 6th Gen. They use uniballs for articulation and handle 2–3" lifts with ease.
- Chromoly tubing with uniball pivots
- Extended travel–ready design
Westcott Designs Billet UCAs (Pre-Order)
CNC-machined billet aluminum with fully adjustable pivots. Built for strength, precision, and high-performance suspension setups.
- Billet aluminum with uniball and heim joints
- Adjustable geometry for custom alignment
Final Thoughts
If you’re lifting your 4Runner, UCAs are one of the first upgrades worth doing. Westcott and Total Chaos lead for premium performance, JBA offers reliable alignment correction, and Ironman gives solid strength at a reasonable price.Let me know if I missed any! What UCA's are y'all running?
