What will be your AUX 1, 2, 3, and 4?
DannyDrives
I would assume lights are a given. Maybe top light bar of some kind? ditch lights? maybe even wheel well lights?
What ideas do you have?
does anyone have any info on these? are they rated to carry a load or just triggers for relays?
My understanding is that they are prewired switches for accessories.
right, but do they carry a 10-30 amp load of lighting , or just a milliamp for a relay pack?
Probably similar to the Bronco Upfitter switches. I had a Bronco when it came out and it's a cool feature to easily wire in an accessory - but you run out of circuits fast - especially if you have lights with dual function. Each switch/circuit is fused and rated for a certain amperage, probably a wide range of 10amps on the low end up to 40amps on the high end. Or it might be in 10amp increments; 10amp, 20amp, 30amp, 40amp for each circuit. Each lead that you connect to is coming from the primary relay pack or distribution block.
Wiring usually looks like this:
Accessory -> lead
Lead -> distribution/relay block
Distribution block -> fuse box
On the Bronco, the leads we're all in random places ready to hook up. Some were located at the grille, some in the footwell, some at the A-pillar, and a couple in the cargo area.
does anyone have a location schematic of where these wire end? meaning where you can grab the ends to tye your lighting etc into them?
