Active member
- Mar 26, 2025
- 120
- 99
Why Choose the KC HiLiTES Platform One Roof Rack for Your 6th Gen 4Runner
I have looked at every roof rack on the market and none of them have come close to the KC HiLiTES Platform One and honestly, it’s been one of the best mods I’ve added so far. I wanted to share a quick breakdown of why this rack stands out compared to the usual suspects like Prinsu, Sherpa, Front Runner and others.
1. Hybrid Design & Build Quality
The Platform One isn’t just another flat rack. It’s a hybrid between a low-profile platform and a traditional basket design — giving you the versatility of a flat rack for RTTs or gear mounts, plus integrated side rails for extra rigidity and tie-down options.
KC went heavy on quality here: aircraft-grade aluminum, powder-coated finish, and rock-solid mounts that feel extremely sturdy.
2. Integrated Lighting & Wiring
This is where this rack really SHINES. The rack is designed around lighting integration, not as an afterthought.
3. Utility & Modularity
Each slat accepts standard accessory mounts, meaning you can add Maxtrax, Rotopax, recovery boards, or rooftop tents without drilling or fabricating custom brackets. KC also offers tie-down rings, awning brackets, and mounting plates that bolt right in.
Basically, it’s a rack that grows with your build whether you’re doing overlanding, trail days, or just weekend trips.
4. Style That Matches the 4Runner
A lot of racks look bulky or tacked-on. The Platform One actually complements the 4Runner’s body lines. The side profile is sleek and aggressive, especially when paired with KC lighting. If you care about both
performance and aesthetics, it nails both.
5. Backed by KC’s Legacy
KC’s been building lighting gear for longer than I’ve been alive, so their reputation for durability and customer service is top notch. The Platform One is a newer addition to their lineup, but you can tell it’s designed by enthusiasts who actually wheel their rigs.
Final Thoughts
If you’re looking for a roof rack that combines functionality, clean lighting integration, and rugged looks, the KC HiLiTES Platform One is absolutely worth a look.
It’s not just another rack, it’s an entire ecosystem built for 4Runner owners who actually use their rigs.
You can see the system for your self at: https://www.kchilites.com/families/platform-one
- Front light bars (available in Amber, Combo, or Spot configurations) that mount seamlessly into the front faceplate.
- Side and rear scene lighting using the new SideCast lights.
- Built-in wiring channels to route cables cleanly through the rack.
It’s easily one of the cleanest lighting setups on the market with this setup looking OEM
Final Thoughts
