Active member
- Mar 26, 2025
- 119
- 99
Hey everyone, I wanted to share some thoughts after spending some time with the KC Platform One on my 6th Gen 4Runner and explain why it genuinely stands out compared to other racks on the market.
Most of us here have spent a lot of time comparing roof racks before pulling the trigger, and while there are plenty of good options, the Platform One feels like a different category altogether.
Heres what sets it apart:
1. Integrated lighting from the start. KC designed this rack around their auxiliary lighting, not as an afterthought. The rack system seamlessly pairs KC Gravity light bars and their new SideCast lights giving you clean wiring routes, protected cable channels, and mounting points that dont require drilling or zip ties. If a rack and lighting setup is part of your build goals, this convenience alone is a game-changer.
2. Modular low-profile design. The profile is tight to the roofline, almost OEM like in its fitment. It doesn't scream “aftermarket,” but feels purpose-built for the 4Runner. Panels and rails are modular, so adding accessories, awning brackets, recovery boards, or a rooftop tent feels natural without swallowing the entire footprint.\
3. Quality built. A huge complaint with some racks is vibration noise and that constant whistle on the freeway. KC uses reinforced aluminum and a multi-point mounting system that feels rock solid. No flex, no rattle, no adjustment rituals every few months.
4. Designed for the trails. KC is a brand deeply tied to off-road culture, and that vibe shows in this rack. The usable tie-downs, edge channels, and ability to handle dynamic load without sagging make it a rack you don’t have to “baby.” Load wood, recovery gear, a kayak, it just works.
Most racks, even premium ones tend to fall into one of these buckets:
function + durability + appearance + lighting ecosystem all hit at the same level.
If you're building a 4Runner for overlanding, daily practicality, or just want a rack that elevates the look of the truck instead of just sitting on top of it, the KC Platform One deserves a serious look. It feels like you're adding capability and style at the same time without compromise.
Check it out here: https://www.kchilites.com/bundle-pl1-toyota-4runner.html
Find 10% off on KC products via 4RunnerMods.com (Use code "6G4RKC" for 10% OFF): https://4runnermods.com/products/2025-toyota-4runner-6th-gen-4runner-platform-one-roof-rack-92308
- Great mounting but poor accessory integration
- Solid build but loud with noticeable drag
- Good lighting compatibility but looks cluttered once everything is installed
