How the Stabilizer with Disconnection Mechanism (SDM) Works on the 2025 4Runner
Increase Suspension Articulation for Off-Road Performance
The Stabilizer with Disconnection Mechanism (SDM) is an off-road feature available on certain 2025 4Runner models that enhances suspension flexibility by electronically unlocking the front stabilizer bar. This improves comfort and control in rugged terrain while maintaining on-road stability. It allows drivers to disconnect the front sway bar to improve wheel articulation and ground contact during off-road driving, then automatically reconnect it for on-road stability. It's similar to Toyota's Kinetic Dynamic Suspension System (KDSS) on the 5th Gen 4Runner, but it only disconnects the front sway bar.
(Reference: 2025 Owner’s Manual, pg. 436–437)
SDM Purpose and Function
When driving on paved roads, the stabilizer is locked to limit suspension movement, which improves cornering and handling.
When activated for off-road use, SDM unlocks the stabilizer to allow greater suspension travel, which helps each wheel maintain contact with uneven surfaces and reduces body vibration.
How to Use SDM​
  1. Make sure the vehicle is traveling under approximately 18 mph
  2. Press the SDM switch located on the dash
  3. The SDM indicator light will turn on
  4. To cancel, press the switch again (indicator turns off)
While the system is shifting between locked and unlocked states, the SDM indicator will flash.
SDM will re-lock automatically once the vehicle exceeds approximately 18 mph. You’ll hear a mechanical sound when the stabilizer bar is engaging or disengaging—this is normal and not a malfunction.
Operating Conditions​
  • Engine switch must be in the ON position
  • Vehicle speed must be at or below 18 mph
  • SDM state is retained even if the engine is turned off; to change it, restart the engine and press the SDM switch again
  • On uneven surfaces, there may be a delay in switching states depending on suspension movement
Limitations​
  • The system may not function properly if the outside temperature is below -22°F (-30°C)
  • If the SDM indicator does not match actual stabilizer status, drive the vehicle briefly to allow the suspension to adjust
  • When SDM is active, some Toyota Safety Sense 3.0 features may be temporarily disabled
2025 4Runner Stabilizer with Disconnection Mechanism Diagram​
Refer to the Owner’s Manual (pages 436–437) for a diagram of the SDM switch and system behavior under different conditions.
Featured
I think this is the 2025 4Runner Platinum in...
Bought a TRD OffRoad Premium using the Costco program through Earnhardt Toyota in Mesa, AZ. We...
On April 8th, I have an appointment with my local tuner to flash the OTT Tune onto my 6th Gen...
I see more and more hybrid 4Runners being unloaded to ports every day on socials! I'm curious...
NYTOP just dropped some more photos of their front bumper for the 6th Gen 4Runner. It looks...
Has anyone else experienced this poor wheel flare fitment on their new 6th Gen 4Runner? It’s...
Alpharex has confirmed that their DoubleTap series fog lights will work with the new 4Runner...
Looks like Alpharex has test fit their 6th Gen 4Runner headlights and they seem to be working! I...
Just went on a rather long road trip with our new 6th Gen 4R. We encountered some issues with...
Hey! I was wondering if any companies have developed any aftermarket grilles yet? Been looking...
Just picked up my ‘25 TRDP from Mt States Toyota in Denver this weekend. Paid MSRP of ~$69,000...
Had my 2018 OFP for 7 years and 125k miles. Hoping the 6th gen is as reliable! It’s a totally...
Damn this actually looks really good! I was a little skeptical seeing this when it wasn't paint...
