Dirt King Tubular UCAs – 6G 4Runner
MVenture
Arizona
Figured I’d share some feedback on the Dirt King tubular UCAs since there isn’t a ton out there yet for the 2025s.
I installed these while lifting the truck (right around the 2–3” range) because the stock UCAs would have limited alignment and droop. Didn’t want uni-balls this time around since this truck sees a lot of daily miles and road trips. Install was pretty smooth. Nice that they come fully assembled—no pressing bushings or messing with joints. Everything lined up as expected. Just pay attention to the pivot bolt orientation and clearance around hoses if you’re running reservoir shocks. Alignment was the biggest improvement. Caster came back in easily and the truck tracks way better on the highway now. Steering wheel return to center is noticeably improved compared to stock UCAs at this lift height.
On-road manners are basically OEM+. No squeaks, no clunks, no added noise, vibration, or harshness. The SilentSpin bushings seem to be doing their job. I’ve had UCAs in the past that needed constant greasing or they would started making noise—so far these have been completely quiet. Off-road, the extra droop is noticeable. It’s not night-and-day, but the front end feels less topped out and more compliant over uneven stuff. Ball joint setup feels solid without the usual uni-ball noise/maintenance tradeoff. Wheel fitment-wise, just make sure your backspacing is in check. I’m on 17s and had no issues, but I can see how certain offsets could get tight at full lock. Price isn’t cheap, but they feel like a “buy once” part. If you’re lifting a 2025 4Runner up to ~3” and want corrected geometry without turning your suspension into a maintenance item, these are worth a look.
I have the Peak Suspension UCA and want to add the KING Shocks. How are they for a daily driver. Are they worth the $4,000?
They have been excellent on and off-road. Most quality suspension setups will be around the same price so I would say they are most definitely worth it, specially if you off-road often. If it's just a daily driver, I'd probably save some cash and go with a more affordable option.
Leveled my 2025 Trd sport in my driveway...
Leveled my 2025 Trd sport in my driveway following the instructions included with Toytec...
What's up, 4Runner homies? We're working on our latest 6G product, a full width front bumper...
Figured I’d share some feedback on the Dirt King tubular UCAs since there isn’t a ton out there...
What's up guys! My name is Mark. I live in Arizona and own a 2025 Heritage Blue SR5 4Runner...
Found this photo on Facebook of an Underground 4Runner TRD Sport with some 3rd Gen Tundra TRD...
WTS my OEM 3/4th ARB Roof Rack off my 2025 4Runner TRD Pro. only mounted to my snow board rack...
My buddy just sent this to me. Pretty solid looking setup.
What's up 6G4R! I've had this Bulletpoint Mounting Solutions accessory dashboard mount in my...
Heads-Up for Anyone Upgrading a Non-JBL Audio System (SR5) Just finished upgrading the entire...
