6th Gen 4Runner Engine Oil Change Guide
2025 (6th Gen) 4Runner Engine Oil Change Step By Step Process on Hybrid TRD OR​
For a reference on oil change intervals and details from the owner's manual, check these threads:
We changed the oil at 1700-miles because there were a few other people on the Facebook group who claimed to have seen an abnormal amount of metal shavings in the oil at around 500-miles. I figured, why not change it now while I had all the supplies and had a weekend free. We used AMS oil SAE 0W-20 because I had it on hand from a previous purchase, although it's definitely overkill for this oil change. Regular TOYOTA SAE 0W-20 motor oil is just fine and is much more affordable than AMS oil - but that's a conversation for another day. We're also going to be testing the oil with an oil analysis kit from https://www.speediagnostix.com/ to check the overall contamination (if any) in the oil. At first glance, we didnt see anything wrong with the oil, it looked clean and clear to the eye but we'll see what the oil analysis has to say. We should get our results back in about a week, so check back in for the results on the oil.
What mileage are you planning to change your oil at, for the first change?
What intervals are you planning to change?
What oil do you use?
Tools and Materials
  • TOYOTA Oil Filter: Oil Filter 90915-YZZN1 Same as 90915-YZZF2
  • SAE 0W-20 - offers ideal performance for fuel economy, engine protection, and cold-start reliability
  • AMS Oil 0W-20 - superior protection, performance, and fuel economy benefits
  • Drain Plug Part Number: 90430-12031 (Thread Size: M12 x 1.25)
  • Washer Size: 12mm aluminum crush washer (Toyota Part #: 90430-12031)
  • Crush Washer (comes with product link above)
  • Oil Grade: ILSAC GF-6A
  • Viscosity: SAE 0W-20
  • Drain Pan
  • Tarp or Cardboard
  • 3/8 Drive Wrench & Metric Sockets
  • Torque Wrench
  • Oil Filter Wrench
  • Foldable Oil Drain Funnel (optional)
0W-20 Synthetic Oil and Toyota Oil Filter​
Again, this oil is overkill for the 4Runner, but if you want the highest-end oil on the market, AMS Oil makes a great product. If you're looking to save some money, just grab the TOYOTA SAE 0W-20 linked above.
1. Prepare Oil Catch Pan & Oil Change Materials​
Warm up the engine. Let it run for 5–10 minutes. Warm oil flows better and carries contaminants out more effectively. Park on a level surface. This ensures even draining and accurate refilling.
Gather your tools. You’ll need a drain pan, socket wrench (14mm for 6th Gen 4Runner), gloves, funnel, and rags.
Start by loosening the oil fill cap first, this helps oil drain faster by allowing air in from the top.
2. Locate Oil Filter​
Locate the oil filter. It's behind the radiator just above the front differential. It's very easy to access. I removed my skid plate so that I could take better photos, but if you have an access port in your skid plate, you should not have to remove your skid plate. It's pretty cool that the new oil filter on the 6th Gen 4Runner has a drain shroud around it, but it still doesn't work as well as we hoped. Because the drain shroud is so small, the oil still drains all over the crossmember. Because of this, we used a foldable oil drain funnel to pour the oil into the catch pan.
3. Remove Oil Filter​
Using an oil filter wrench, crack the oil filter loose and then prep the oil catch pan.
4. Drain Oil​
Drain the oil until you don't see any oil coming out. It shouldn't take more than 10 minutes for the motor to fully drain. As we were draining the oil, we didn't notice anything unusual. The oil was clean and for the most part, very clear, which was to be expected at 1700 miles.
5. Prepare New Oil Filter (90915-YZZN1)​
Take a bit of the new oil and coat the bottom of the oil filter to ensure a better seal and to make future removal of the oil filter easier.
6. Screw On New Oil Filter​
Screw on the new oil filter and-tighten only, after the gasket makes contact with the engine, tighten the filter an additional 3/4 to 1 full turn by hand. This ensures a proper seal without over-compressing the gasket. Do not use a wrench to tighten the oil filter, as overtightening can crush the gasket or damage the housing. Always check for leaks after starting the engine.
7. Drain The Oil Pan​
Now, drain the oil pan. Position the drain pan slightly back from the plug towards the passenger tire, oil will shoot out at an angle when the bolt is first removed.
Remove the drain plug slowly while applying inward pressure until it’s ready to come off, then pull it away quickly to minimize splashing. Let it drain completely, give it several minutes until it’s down to a slow drip.
Inspect the drain plug and crush washer. Replace the washer with your aluminum crush washer provided with the filter you bought.
8. Inspect the Drain Plug & Remove Old Crush Washer​
Clean the drain bolt and wipe the area clean around the oil pan. If the crush washer is stuck to the oil pan, you can pop it off with a small flathead screwdriver.
9. Reinstall the Drain Plug and New Crush Washer​
Prepare the drain plug and new crush washer. Then torque it to 30 ft-lbf (40 N·m). Always install a new crush washer, reusing the old one can cause oil leaks.
10. Prepare New Oil & Funnel​
The 6th Gen 4Runner has a plastic baffle (splash guard) built into the valve cover. The baffle prevents oil splash-back during engine operation, reduces oil vapor and mist entering the PCV (positive crankcase ventilation) system, and protects internal components from debris or accidental tool drops during maintenance. That said, it makes fitting a funnel into the valve cover a bit difficult if you have a narrow tip funnel. You may have to have someone hold a funnel in place while you pour in the oil. If you have a wide tip funnel, it makes the pour easier.
Oil capacity on the 6th Gen 4Runner depends on whether or not the oil filter is replaced during the change:
  • With Filter: 5.9 qt. (5.6 L)
  • Without Filter: 5.6 qt. (5.3 L)
After you fill your oil, you're all set. Now, just reset the factory maintenance settings from inside the vehicle.
11. Reset the Factory Maintenance Settings​
very good write up. I just changed my oil last week at 2k miles. I used the same oil filter (I couldn't get it off and didn't have an oil filter wrench, I'll buy one when I get and drop the old oil off at an auto zone). I'm not terribly worried about not changing the oil filter, I have a free oil change thru Toyota care at 5k miles so they will do it.
I also did not replace the crush washer (did not know I needed too until I saw your thread, but again I'm sure Toyota will do it at 5k so I'm not overly worried and there has been no leaking either).
When I drained my oil, it looked very clean. I looked reasonably hard for any particulates and didn't see any. I used Toyota genuine motor oil and bought the Toyota filter which I didn't end up using as I didn't get the other one off.
Today I learned that there is such a thing as a flexible oil funnel... Amazon, here I come!
OK, my girlfriend name er "Bluey" so sue me...
I added the beautiful candy red TRD UCAs onto...
Setting up this thread as a guide/resource for ditch light setups as they become available for...
Local dealer just happened to have a Trailhunter on the lot. I stopped in first thing and asked...
OK, my girlfriend name er "Bluey" so sue me. Am I imagining the windshield-side edge of the...
So the new 4Runner comes with a 14” infotainment screen along with an 8" screen for lower...
2025 (6th Gen) 4Runner Engine Oil Change Step By Step Process on Hybrid TRD OR For a reference...
I added the beautiful candy red TRD UCAs onto my 6th Gen 4Runner TRD Off Road. These things look...
I recently installed the Alpharex “OG” Nova Series Headlights on my 6th Gen 4Runner. These this...
Westcott Designs is gonna be offering a 3/4 basket style roof rack for the new 6th Gen 4Runner...
Any North West Florida peeps here? YotaMafia is having an OPEN HOUSE on June 7th! I'll be there...
A little over two months ago, I installed the Overland Tailor Tune to my 6th Gen Toyota 4Runner...
Hello all! Post your Beautiful Photos of your rig doing 4runner things!
