6th Gen 4Runner Center Mount Rear Bumper
6th Gen 4Runner Rear Bumper by Rago Fabrication​
Rago dropped their new rear bumper for the 6th Gen 4Runner and figured I’d share some thoughts on it. Honestly, it looks like a solid option if you don’t want something super bulky hanging off the back but still want more strength than the factory setup. The design is low-profile, which I really like; I am a huge fan of the OEM aggressive style on these new-gen Toyotas. My question is does a low-profile rear bumper make sense? Is the departure angle and strength leagues above stock?
Here’s what stood out to me:
Steel Construction
The steel build should take a hit better than the factory bumper, which I honestly like for road driving more than on the trail. I have been rear-ended a couple of times in my last rig, and it would be great if I didn't have to replace the tailgate again.
Low-Profile Design
Doesn’t stick out a mile behind the truck. Clean look, and it lets you keep factory sensors. I am not a huge fan of cutting, something about never being able to undo it, it's not my favorite, but I think it's worth it could always upgrade to a full bumper down the road.
Integrated Pod Light Mounts
Nice touch with the cutouts for two pods (Baja S2 or RIGID SR-M). Super useful for lighting up camp or backing up at night.
Made in the USA
Always good to see.
Pros/Cons from my perspective:
  • Pros: Clean look, keeps sensors, pod light mounts, high-strength, USA-made.
  • Cons: Not a huge clearance upgrade, and install requires trimming (would like to see how much).
Overall, seems like one of the cleaner bumper options out right now for the 6th Gen. Curious what you guys think — worth it, or are there other rear bumper setups you’d be waiting on?
Check it out online: https://www.ragofabrication.com/products/6th-gen-4runner-rear-bumper
There is a fair bit of cutting once you pull the factory bumper off. Rago’s install guide lays out the cut lines necessary, so definitely follow that closely. They recommend using a jig saw for the cuts, which should wor really well on the plastic. What I’d add is to take the extra time to tape off where you’re cutting before you start. It makes it a lot easier to keep the lines straight and avoid slips, plus it gives you a cleaner edge when you’re done.
One more thing worth mentioning when you’re transferring over the factory sensors, be really careful. They can be a little fragile when you’re popping them out of the stock bumper, and you don’t want to crack one. Take your time there, and it should go smoothly.
Dissent Offroad Build – 2025+ (6th Gen) Toyota...
What is the largest tire size that can fit a...
I want to thank WOLFBOX who contacted me about...
Dissent Offroad Build – 2025+ (6th Gen) Toyota 4Runner TRD Off Road Premium Our 2025 TRD ORP...
Finally got around to taking some measurements on the 6th Gen today. Some of the most important...
What is the largest tire size that can fit a completely stock 4runner? No trimming
I want to thank WOLFBOX who contacted me about doing an installation and review on their new...
Incredibly stoked to share this one with you guys. The first drawer system on the market for the...
6th Gen 4Runner Rear Bumper by Rago Fabrication Rago dropped their new rear bumper for the...
Hey everyone, We’ve been working on a prototype rear recovery point for the 4Runner and wanted...
I see more and more hybrid 4Runners being unloaded to ports every day on socials! I'm curious...
I just wrapped up installing the Peak Suspension 2-piece collar lift kit on our 2025 TRD...
Thoughts on anything for the 2026 Model year for 4Runner? I know the vehicle is brand new, but...
So, the i-FORCE engine is solid for everyday driving. It’s got a good mix of power and...
