Largest tire size to fit stock SR5, no trimming
zevinsanchez
What is the largest tire size that can fit a completely stock 4runner? No trimming
Usually, anything below a 0mm offset is going to be way too aggressive. The trailhunters and pros are on a +25 offset. Other models (TRD Offroad, Sport, Limited, etc. all have all+55mm offset. If you want more stance/poke, you’ll need a smaller tire or to remove mudflaps, crash plates, and pin the fender well back. I've seen the 285/70/18 Nitto Ridge grapplers (33.9") tire fit with no lift or rub, but on a stock offset of +25. These 4Runners are really designed around a max of +25mm offset with 285/70/18 tires. If you want to go with a 17" tire, then look at a 285/75/17 with +25mm wheels and you will be fine.
What’s up 6G4R 👋 Josh here, checking in from...
Selling my OEM cast aluminum TRD running...
See title. Need some build inspiration. Let's...
What’s up 6G4R 👋 Josh here, checking in from Seattle with my Ice Cap 2025 TRD Pro 4Runner that...
It’s likely I’ll be getting a 6th gen TRD PRO by the end of ‘25 and wanted to open a little...
See title. Need some build inspiration. Let's see some pics!
So I added XPEL PRIME XR PLUS Window Film to my new 6th Gen just in time for Florida Spring and...
I spent time with 2026 4Runner Platinum yesterday, and I wonder if it's the best of all the...
Selling my OEM cast aluminum TRD running boards. Only a few months old; purchased from Roseville...
Hey 4runner gang looking for some opinions for my 1st 4runner This vehicle will be my daily...
Hey everyone, stoked to be here! We’re IRONMAN 4X4, and at our core, we’re enthusiasts who care...
