4Runner Antenna Tips and Tricks
bradSRT88
I know the Gen 6 is a relatively new vehicle and not so many tips and tricks are out there yet. So I wanted to share some antenna tips and tricks that I use and any Gen 6 owner could also try them out on his vehicle. I hope someone finds this post helpful
ANTENNA TIPS AND TRICKS
• To maximize range, mount your antenna as high as possible.
• Don't install a bullbar antenna with the base near or above the roof line.
• Don't install a fiberglass antenna on a lip mount, as it is not secure enough.
• The best place to route your cable from the cab to the front of the vehicle is through the firewall. There should be a rubber grommet you can use for access.
• When attaching your antenna mount to the coax cable, do not over-tighten.
• To properly ground your antenna, ensure the mounting surface is bare metal without powder coating or paint. Additional antenna grounding is not necessary with GMRS, but may help overall performance.
• To avoid signal obstruction and interference, keep your antenna away from light bars, GPS antennas, cables, roof racks, air scoops, etc.
• When routing the antenna cable always keep it away from power cables, intercom cables, ignition cables/coils, engine electronics, and any other cables.
• If radio interference occurs, clip ferrite core beads to the antenna cable to suppress noise.
• Always avoid tightly coiling or bundling any excess antenna cable. If the cable is too long, shorten it by cutting the cable and using a PL259 Male Crimp Connector kit. You can also route the cable to use the excess length.
• Use hooks and cable wrap to secure the cable. Avoid zip ties if possible.
