- 850
- 591
6th Gen 4Runner Dual Compressor or Switch Mounting Bracket (Multi-Mount)
Finally wrapped up the ARB dual compressor installation using this mounting bracket from SLEE. Compatible with the 4th Gen Tacoma, 6th Gen 4Runner and 250 Land Cruiser.SOK2105 - ARB Compressor / Multi Mount
- https://sleeoffroad.com/products/sok2105/
- Fits ARB Single (classic & brushless) and Twin compressors (classic & brushless).
- When using ARB twin compressor the ARB manifold kit and Pump Up Kit is recommended
- Stainless Steel
- 4th Gen Tacoma and 6th Gen 4Runner require Redline hood struts (or similar) as the original hood prop conflicts with the compressor
- BLUESEA 5028 Fuse Holder
- BUSSMAN JB3816 or BLUESEA 2003 Studs
- BUSSMAN LMI1-E-0-0 Fuse Holders
- ARB Manifold
- ARB Single Compressor
- ARB Air Chuck
- REDARC DCDC or ALPHA
- ARB Twin Compressor
- ARB Brushless Twin Compressor
- ARB Brushless Single Compressor
The bracket itself is incredibly well designed. SLEE uses clip nuts throughout the whole design, which makes the installation incredibly simple. You dont have to mess with bolts, nuts and two washers at every point, just insert the clip nuts and bolt everything down. All the brackets drop into place for a pretty quick relocation of the primary ECU and transmission ECU. The best part about this bracket is that it is incredibly universal. You can mount an ARB classic dual compressor, brushless, single compressor, or any of your preferred switch systems; SwitchPros, Auxbeam, etc. SLEE offers a specific bracket for the SwitchPros (https://sleeoffroad.com/products/sok2108/). The little details really make this bracket; well thought out zip-tie points for the ARB harnesses, mounting points for ARB compressor switch, mounting point for the ARB QD fitting, clip mounting points for the factory harness, and enough play with the clip nuts to make mounting very easy.
SLEE provides really dialed installation instructions for the bracket install portion, but you're on your own for the compressor wiring installation. Thankfully for you, I put together a super detailed installation guide of the wiring process on Trail4Runner.com.
Full installation guide on Trail4Runner.com:
6th Gen 4Runner ARB Brushless Compressor Install & Wiring Guide
Slee Off-Road Multi-Mount Compressor Bracket Review & Install 6th Gen 4Runner, ARB Brushless Compressor Install & Wiring Hybrid 6G 4Runner
Take a look at the full installation guide and schematics for additional accessory mounting options (compressors, switches, Redarc systems, Blue Sea accessories, etc.): https://sleeoffroad.com/tech-zone/installation-instructions/sok2105-media/
