Link & Discount Code: https://cbioffroadfab.com/?ref=TRD+Jon
Code: TRDJON
Recently added the Prinsu Accessory Panel to my Prinsu Pro rack on the 6th Gen 4Runner — super slick upgrade if you’re running any gear up top and ran outta space.
Install was quick, fitment is perfect, and it adds a ton of mounting options for gear like Rotopax, shovels, traction boards, and more. The slotted design gives you flexibility to adjust or swap setups without needing extra brackets. It would also be perfect for radio antennas, quick fists, or lighting. Definitely helps keep things organized and secure without cluttering the main rack area.
Worth it if you’re looking to level up your roof setup. I like how it covers all the way to the C-Pillar as well and not just the rear window like other options on the market. Prinsu definitely maxes out the space avaialble. I paired it to my Pro Roof Rack which made the install super easy as well.
