305/70r17 Best Offset 6G 4Runner
Sparky85
Hey everyone, I’m gonna be putting 305/70r17 Nitto Recon Grapplers on my 25’ 4Runner that has a readylift 2.5”. What offset do you recommend to minimize trimming/modification on a 17x8.5 wheels?
Those tires are a 33.81" size, so you should be good with the 2.5" lift on +35mm offset wheels - all day - no trimming. You can even push it a bit up to +25mm wheels, depending on how aggressive you want the stance. With the +25mm wheels, you're still in the clear zone of cutting the body - maybe just removing some factory plastics.
Hello, anyone here know if the TRD Pro...
Hey everyone, I’m gonna be putting 305/70r17...
Installed CBI ditch brackets. Pretty easy and quick. Did 1 bolt at a time starting with bolt...
Hello, anyone here know if the TRD Pro headlight assembly fits on a SR5, Is it plug in play?
Hey everyone, I’m gonna be putting 305/70r17 Nitto Recon Grapplers on my 25’ 4Runner that has a...
Looks like Toyota has finally made a TSB for the 6th Gen 4Runner and Land Cruiser 250 brake...
Its the little things that make your life easier, and this is one of them , if your ever under...
black OEM roof rails and/or cross bars. $200 cash for either pair. Local pick up. Thanks!
Good for full size spare. 1015 miles on the tires. Yokohama geolandar 245/70/17. No TPMS. Local...
Here it is! The carbon fiber hood for the 6th gen! 🏆 This thing is super lightweight, fits...
First-Time Overlanding Vehicle Recommendations Hi everyone! I'm looking for some guidance on...
Here is a chart and graphics of all the available wheel size and tire size options that come...
