Ditch Light Brackets for 6th Gen 4Runner
K2Runner
Ditch Light Brackets for the 2025+ 4Runner​
Ditch light brackets are one of the easiest upgrades to make your 6th Gen 4Runner more capable after dark. They mount at the hood corners to throw light down the trail or to the sides where your headlights can’t reach. You’d want them for night runs, camping setups, or just a clean, functional look that actually adds visibility.
CBI Offroad Ditch Light Brackets​
Strong, clean, and built to take abuse from the weather. Steel construction with a precise bolt-on fit.
Check Price: CBI Offroad Fab
Cali Raised LED Ditch Light Mounts​
Lightweight and low-profile with a subtle OEM-style look. Quick install using factory hardware.
Check Price: Cali Raised LED
DV8 Offroad Ditch Light Brackets​
Simple, functional, and a dual light setup. Clean fitment and a solid finish.
Check Price: DV8 Offroad
KC HiLiTES Ditch Bracket Set​
Great pick if you’re already running KC pods or plan to in the future.
Check Price: KC HiLiTES
Rago Fabrication Ditch Light Brackets​
Heavy-duty and well-finished with great rigidity. Made from CNC-cut steel with a dual-stage coating.
Check Price: Rago Fabrication
Westcott Designs Ditch Light Brackets​
Tight fit and clean lines that look factory. Designed for minimal wind noise and quick installation.
Check Price: Westcott Designs
CAtuned Off-Road Ditch Light Brackets​
Balanced build that’s tough but not bulky. Coated steel with a flush fit along the hood.
Check Price: CAtuned Off-Road
Final Thoughts​
Ditch light brackets are an easy install that adds real function and visibility when the sun goes down. Whether you want a clean daily driver setup or a full trail-ready lighting package, you honestly can’t go wrong with any of these options. Every one of them gets the job done and makes the 4Runner more capable where it counts.
Hey All- I really like the look of these...
Perry Parts Front Bump Stops for 2025+ (6th...
I have squealing front brakes on my 2026 TRD...
Drafting up this post as a guide/resource for those who need help with electrical mods, wire...
