Why Choose the KC HiLiTES Platform One Roof Rack
kophoto4x4
Active member
Why Choose the KC HiLiTES Platform One Roof Rack for Your 6th Gen 4Runner
I have looked at every roof rack on the market and none of them have come close to the KC HiLiTES Platform One and honestly, it’s been one of the best mods I’ve added so far. I wanted to share a quick breakdown of why this rack stands out compared to the usual suspects like Prinsu, Sherpa, Front Runner and others.
1. Hybrid Design & Build Quality
The Platform One isn’t just another flat rack. It’s a hybrid between a low-profile platform and a traditional basket design — giving you the versatility of a flat rack for RTTs or gear mounts, plus integrated side rails for extra rigidity and tie-down options.
KC went heavy on quality here: aircraft-grade aluminum, powder-coated finish, and rock-solid mounts that feel extremely sturdy.
2. Integrated Lighting & Wiring
This is where this rack really SHINES. The rack is designed around lighting integration, not as an afterthought.
  • Front light bars (available in Amber, Combo, or Spot configurations) that mount seamlessly into the front faceplate.
  • Side and rear scene lighting using the new SideCast lights.
  • Built-in wiring channels to route cables cleanly through the rack.
    It’s easily one of the cleanest lighting setups on the market with this setup looking OEM
3. Utility & Modularity
Each slat accepts standard accessory mounts, meaning you can add Maxtrax, Rotopax, recovery boards, or rooftop tents without drilling or fabricating custom brackets. KC also offers tie-down rings, awning brackets, and mounting plates that bolt right in.
Basically, it’s a rack that grows with your build whether you’re doing overlanding, trail days, or just weekend trips.
4. Style That Matches the 4Runner
A lot of racks look bulky or tacked-on. The Platform One actually complements the 4Runner’s body lines. The side profile is sleek and aggressive, especially when paired with KC lighting. If you care about both
performance and aesthetics, it nails both.
5. Backed by KC’s Legacy
KC’s been building lighting gear for longer than I’ve been alive, so their reputation for durability and customer service is top notch. The Platform One is a newer addition to their lineup, but you can tell it’s designed by enthusiasts who actually wheel their rigs.
Final Thoughts
If you’re looking for a roof rack that combines functionality, clean lighting integration, and rugged looks, the KC HiLiTES Platform One is absolutely worth a look.
It’s not just another rack, it’s an entire ecosystem built for 4Runner owners who actually use their rigs.
You can see the system for your self at: https://www.kchilites.com/families/platform-one
The SideCast lights are an add on option so it does not come pre-wired. The wiring is super easy though you just slide the wires in. KC makes it really simple to make it look clean!
That is a nice system, well thought out and lifetime warranty is awesome, especially from a company like KC but wow, 5K+ would seem to keep the target market pretty low????
Thanks for sharing this @kophoto4x4 - we're stoked to see that you are enjoying the Platform One. We've been working on this rack for quite some time now, and one of the main goals of the entire system was not only to bring something unique to the market, but to bring the manufacturing locally to ensure a higher level of production and quality control. Platform One is built locally in small batches to deliver strength, versatility, and a clean, contoured design that is ready for every adventure, whether it's on a new 6th Gen 4Runner, 5th Gen 4Runner, or many other makes/models on the road.
If anyone has any questions at all on the rack, lighting integrations, how to wire specific lights, integrate solar, mounting storage boxes, or anything else... let us know. We're always around.
Back in 2019, Trail4r provided some excellent...
Taken off today, 10/24/25 at 3400 miles. No...
Back in 2019, Trail4r provided some excellent advice for suspension upgrades when I was buying...
Okay guys, after many people have asked for it, 4RunnerMods and the designer...
I finally got the Prinsu rack installed on the TRD Off-Road Premium and wanted to share a quick...
Ok guys, here is my unrealistic build mockup. 6th Gen 4Runner Supersonic Red sitting on 37"...
I noticed in the rear cargo area of the 4Runner is very poorly lit from the two low lights. I...
Setting up this thread as a guide/resource for ditch light setups as they become available for...
KC HiLiTES Underhood Lighting Kit Installation on 6th Gen 4Runner (2025+) Finally got around to...
Hey everyone, James here from Customs Unlimited! The Largest Selection of Automotive Lighting...
KC Lights has had this 4th Gen Tacoma and 250 Series Land Cruiser switch tray out for a while...
I just installed the Husky Low Profile Vent Visors (Husky Liners Outside Mount Low Profile...
