- 867
- 622
SDM Vs. KDSS - What's the Difference?
Stabilizer Disconnection Mechanism (SDM) and Kinetic Dynamic Suspension System (KDSS) are both off-road focused technologies employed by Toyota to enhance off-road performance and stability. However, they function differently:
- Stabilizer Disconnection Mechanism (SDM):
- SDM disconnects the stabilizer bars (also known as sway bars) for greater wheel articulation.
- The purpose is to allow each wheel to move more independently over rough terrain, improving traction and comfort.
- SDM can be engaged manually by the driver through a button in the cabin which triggers an electronic actuator at the disconnect housing.
- SDM is only available on the front suspension.
- Kinetic Dynamic Suspension System (KDSS):
- KDSS is an interconnected series of hydraulic lines developed by Toyota that adjusts the stiffness of the stabilizer bars in response to driving conditions.
- Unlike SDM, KDSS does not disconnect the stabilizer bars entirely. Instead, it adjusts their stiffness.
- In off-road situations under 12mph, KDSS can increase wheel articulation by reducing the stiffness of the stabilizer bars.
- In on-road situations over 12mph, KDSS automatically increases stabilizer bar stiffness to minimize body roll and improve handling.
- KDSS is a system integrated on all four corners of the suspension whereas SDM is only offered on the front suspension.
Pros of SDM?
- SDM can be easily deleted if you don't want front sway bars.
- If you're looking to add a long-travel setup, for example, you might want to remove the system entirely.
- SDM can be enabled at any speed (under or over 12mph - compared to KDSS)
- There are no hydraulic lines on the frame rail, potentially making it easier to install rock sliders.
- The large hydraulic valve block with check valves connected to the bars can be challenging to design aftermarket skid plates around.
After owning vehicles with both of these systems, I would much rather have the SDM than KDSS.
What do you guys think? Any other pros and cons of SDM that you can think of?
