Rock Rails and Running Boards
Bernie
RVA
Are rock rails and running boards complementary, redundant or mutually exclusive?
What I meant to ask as does it make sense to have both rock rails and running boards or do they conflict with one another? If that's the case, I'll choose the rock rails. My concern is just how high will I have to step to get in to the vehicle. I suppose there is probably an after market removable step for everyday use.
Okay, let's try this again. I'm going to be a first time off road buyer with the new 4Runner TRD Pro (however long that takes!). I went through the build your model on the Toyota site and saw options for both rock rails and running boards. Looking at TRD Jon's new ORP, he has the running boards. They look nice and would give pretty good access to the roof rack. BUT, I kinda have a feeling that they wouldn't serve the same purpose as the rock rails and may even get in the way of rock rails. Can anyone bring this newbie up to speed?
Running boards and rock rails typically bolt on to the same places, so it's a one-or-the-other type of situation. Running boards do not offer much for protection, they're basically just steps. Rock rails will give you protection in one of the places that you're most likely to damage if you offroad over rocky terrain. Some rock rails will protrude a bit from the vehicle and can be used as running boards (steps) as well, but that depends on the manufacturer.
Rock Rails or sliders bolt to the frame, running boards bolt to the body on the 6GR.
I prefer rock sliders. The essentially do the same thing as a running board however they sit closer to the body and provide protection from rocks when you take it off roading.
New here, I have a 6th Gen Hybrid. Trying to...
