Prinsu Pro Roof Rack installed on 6th Gen 4Runner
I installed the Prinsu Pro Roof Rack on my 6th Gen 4Runner TRD ORP. I’ll get this outta the way first, no insane wind noise! Super pumped on that because the wind fairing had a rather large gap from the body line of the 4R so I was concerned.
But this thing is beefy! With the double side wall it has, thick new extrusion bars, and plenty of screws to keep it all together. The install process was fine, I wish instead of having 3 side rails to mount on each side, they just used a thicker single piece, it was a little tricky to line it all up perfectly.
But aside from that I’m super happy!
Solid specs on the Prinsu Pro. Also running a Prinsu Pro on the 5th Gen.. It's a quality unit.
Not live yet on Prinsu but should be soon: https://prinsu.com/category/toyota/4runner/
-All new crossbar that is 44% stronger
-6 integrated drop-in points per crossbar
-No drill installation
-Corrosion-resistant stainless steel hardware
-Two-part side rail design increases rigidity
-Bend on top of Pro Side Rail
-Recessed bolt-on mounting feet
-Ships free to the lower 48
-Increased load capacity, 700lbs dynamic – 1200lbs static
Install video from CBI - looks just like the 5th Gen.
Thanks for the specs dude!
For the full step-by-step installation, check out this thread:
Hey All- I really like the look of these...
Perry Parts Front Bump Stops for 2025+ (6th...
I have squealing front brakes on my 2026 TRD...
Drafting up this post as a guide/resource for those who need help with electrical mods, wire...
