Prinsu Pro Roof Rack installed on 6th Gen 4Runner
I installed the Prinsu Pro Roof Rack on my 6th Gen 4Runner TRD ORP. I’ll get this outta the way first, no insane wind noise! Super pumped on that because the wind fairing had a rather large gap from the body line of the 4R so I was concerned.
But this thing is beefy! With the double side wall it has, thick new extrusion bars, and plenty of screws to keep it all together. The install process was fine, I wish instead of having 3 side rails to mount on each side, they just used a thicker single piece, it was a little tricky to line it all up perfectly.
But aside from that I’m super happy!
Solid specs on the Prinsu Pro. Also running a Prinsu Pro on the 5th Gen.. It's a quality unit.
Not live yet on Prinsu but should be soon: https://prinsu.com/category/toyota/4runner/
-All new crossbar that is 44% stronger
-6 integrated drop-in points per crossbar
-No drill installation
-Corrosion-resistant stainless steel hardware
-Two-part side rail design increases rigidity
-Bend on top of Pro Side Rail
-Recessed bolt-on mounting feet
-Ships free to the lower 48
-Increased load capacity, 700lbs dynamic – 1200lbs static
Install video from CBI - looks just like the 5th Gen.
Thanks for the specs dude!
For the full step-by-step installation, check out this thread:
Hello, I wanted to know if Sherpa is a good...
I removed my spare tire, but was wondering...
Hello, I wanted to know if Sherpa is a good overall quality/brand for 4Runner and specifically...
Ground Clearance, Approach Angle, Departure Angle, Breakover Angle SR5 / Sport / Limited /...
I removed my spare tire, but was wondering what anyone was doing with the remaining, now-empty...
Hi all - I just put KO3s on my trail hunter, and am wondering about correct tire pressure on the...
It is finally here! The KC Hilites Platform One Roof Rack and it does not disappoint! I have had...
I am coming from a Lexus GX460 which had the smoothest ride. Kept it stock. The wheel/tire...
Okay guys, the first high clearance “Mustache Delete” bumper has arrived. Although it's not 100%...
Isn't it funny how one modification leads to another, and so on.....Well that's half of the fun...
TRD Hurricane Edition Emblem was my design and KASauto on Etsy made it for me. GoPro mount for...
Has anyone encountered this yet with your new 4Runner? It’s starting to get humid here in FL and...
Finished my sleeping platform for my 6th gen TRD Off Road and tried out this mattress. Boy does...
