- 838
- 584
KC Lights has had this 4th Gen Tacoma and 250 Series Land Cruiser switch tray out for a while now. I wanted to see if it would fit on the 6th Gen 4Runner, and it does. There are a ton of crossover products from the 4th Gen Tacoma, 250 Series, and 6th Gen 4Runner. Here is another one. I will have a full step-by-step installation guide with this tray and the Cali Raised LED switch + bezel soon. I already started working on everything, and it's coming together.
This tray is designed to be used with their rock light kit, which includes a bus bar for power and a ground terminal as well, however, it's pretty universal. I will be mounting a Cali Raised LED Switch + Blue Sea Breaker on the tray.
Installation is super easy, three factory bolts and one provided bolt to hold the tray together.
- Find it online: https://www.kchilites.com/2024-toyota-tacoma-land-cruiser-cyclone-led-engine-tray-kit-357.html
1. Loosen the Bolt for the Leg Support
2. Tighten The Leg Support Bolt
3. Remove Two OEM Bolts Against the Firewall
4. Tighten All Bolts Down and Tighten the Tray to the Leg Support
