KC Hilites Tacoma & LC250 Switch Tray Is Compatible with 6th Gen 4Runner
KC Lights has had this 4th Gen Tacoma and 250 Series Land Cruiser switch tray out for a while now. I wanted to see if it would fit on the 6th Gen 4Runner, and it does. There are a ton of crossover products from the 4th Gen Tacoma, 250 Series, and 6th Gen 4Runner. Here is another one. I will have a full step-by-step installation guide with this tray and the Cali Raised LED switch + bezel soon. I already started working on everything, and it's coming together.
This tray is designed to be used with their rock light kit, which includes a bus bar for power and a ground terminal as well, however, it's pretty universal. I will be mounting a Cali Raised LED Switch + Blue Sea Breaker on the tray.
Installation is super easy, three factory bolts and one provided bolt to hold the tray together.
1. Loosen the Bolt for the Leg Support​
2. Tighten The Leg Support Bolt​
3. Remove Two OEM Bolts Against the Firewall​
4. Tighten All Bolts Down and Tighten the Tray to the Leg Support​
A little over two months ago, I installed the...
Cali Raised LED Switch & Bezel + KC Lights Switch Tray Wiring Guide: 12V Relocation Cargo Area...
So the new 4Runner comes with a 14” infotainment screen along with an 8" screen for lower...
Setting up this thread as a guide/resource for ditch light setups as they become available for...
KC Lights has had this 4th Gen Tacoma and 250 Series Land Cruiser switch tray out for a while...
So I’m at Toyota‘s headquarters right now and I got to see the new 2026 Toyota 4Runner in the...
300 miles on my first 4Runner and the Brakes going in reverse sounds so bad for a new truck...
Matthew brought us his fresh 2025 4Runner TRD Sport with just over 1,000 miles on the clock and...
Ok guys, making the plunge on a plate system for the cargo area on the TRD OR Hybrid. I just...
A little over two months ago, I installed the Overland Tailor Tune to my 6th Gen Toyota 4Runner...
WHat have you all been hearing about this current 6th Gen 4Runner QC hold? Steering Shafts...
Turns out there’s nothing in stock so I have to order my volks… anybody know if 18x9 0 offset...
