- Aug 19, 2025
- 56
- 26
Fog Light Buyers Guide (2025+)
I’ve been looking into lighting upgrades for the new 4Runner and wanted to share what I’ve found. The stock setup does the job, but it falls short once you’re in rough weather or on dark trails. Upgrading your fogs can make a huge difference in both visibility and appearance.Fog Lights
- Wide, low beam pattern designed to cut through fog, rain, snow, and dust
- Mount directly in the factory fog pockets
- Focused on function and a big step up in visibility
- Accent lights that fill the “fang” openings near the lower grille
- Often feature DRL, sequential turn, or amber/white accent modes
- Primarily for style but pair well with upgraded fogs
Alpharex
Switch between white and amber with a dual projector design.
- Two colors in one kit
- Clean projector look
Baja Designs
Built tough with a clear or amber lens option.
- Heavy-duty output
- Rugged sealed housing
Form Lights
A solid option with factory-style fitment and good light spread.
- OEM-style mounting
- Bright LED upgrade
- Plug-and-play wiring
Cali Raised
Budget-friendly but a big step up from stock.
- Drop-in replacements
- Bright LED output
- Affordable upgrade
Rigid Industries
Premium SAE-compliant fog kit with yellow lenses for better performance in poor weather.
- Direct-fit OEM fog replacement
- Selective yellow beam reduces glare
- Durable IP-rated housing
