CV Axle Spline Count and Rear Axle Shaft Spline Count 6th Gen 4Runner
Finally got around to taking some measurements on the 6th Gen today.
Some of the most important were the spline counts on the front CV stub shaft and the rear axle shafts.
2025 TRD ORP
  • Front CV stub shaft: 30 spline
  • Rear Axle shaft: 32 spline
Some other measurements:
Front CV STUB SHAFT diameter: 27.74mm
Rear Axle Shaft Diameter: 35.08mm
One really annoying part about pulling the hubs and shafts out from the rear is that the brake link bracket is connected to the hub so if you want to remove the hub shaft assembly you also have to remove the brake line. It’s easy to disconnect, pull the shaft and reconnect but requires a brake bleed at the end of the day. Pretty annoying.
Rear axle shaft length (from flange mounting surface): 29 13/16”
Removing the tie rods have changed a bit. Since you can’t knock the side of the outer tie rod mount with a hammer anymore, because the spindles are aluminum, this was the workaround. Just flip the nut upside down and use a rubber mallet to hammer the tie rod joint down and out. Not ideal because it causes stress on the joint, but it works.
Another interesting fact is that the Tacoma CV axles are bigger on the inner joint and have bigger axle shafts than the 4Runner… it seems like all trims and all models. Doesn’t matter, Tacoma just has bigger CV joints and shafts than the 4Runner. The 4Runner is limited in travel because of the CV joints. From what I’ve heard, ICON VEHICLE DYNAMICS tested the travel on the 4Runner vs. Tacoma with the same kit and the 4Runnner CV was binding an entire ~3” before the Tacoma CV joints. That said, there is going to be a huge market for aftermarket CV AXLES on the 6th Gen 4Runner. I’ll make another thread on this one later.
We know that Longfield (TrailGear) makes a 250 Land Cruiser upgrade which is essentially a TACOMA CV axle (35 spline inners and 30 spline outers). The 250 should be running the same front diff and same bearing pack so in theory, the Longfield IFS Axle Set for 2024+ Toyota Land Cruiser LC250 should work on the 6th Gen 4Runner as a pretty stout upgrade for those who are curious.
Killer post dude thanks for the info... So the TRD ORP has the biggest rear shaft Toyota makes for these new gens but sounds like the front CV shafts are lacking. I wonder if the TRD Pro 4Runner has the same front CV axle or if the TRD Pro gets 32 spline outer and inner shafts. Hmmmm.
Does anyone know with a TRD Pro if you have 32 spline or 30 spline axle shafts?
Dissent Offroad Build – 2025+ (6th Gen) Toyota...
What is the largest tire size that can fit a...
I want to thank WOLFBOX who contacted me about...
Dissent Offroad Build – 2025+ (6th Gen) Toyota 4Runner TRD Off Road Premium Our 2025 TRD ORP...
Finally got around to taking some measurements on the 6th Gen today. Some of the most important...
What is the largest tire size that can fit a completely stock 4runner? No trimming
I want to thank WOLFBOX who contacted me about doing an installation and review on their new...
Incredibly stoked to share this one with you guys. The first drawer system on the market for the...
6th Gen 4Runner Rear Bumper by Rago Fabrication Rago dropped their new rear bumper for the...
Hey everyone, We’ve been working on a prototype rear recovery point for the 4Runner and wanted...
I see more and more hybrid 4Runners being unloaded to ports every day on socials! I'm curious...
I just wrapped up installing the Peak Suspension 2-piece collar lift kit on our 2025 TRD...
Thoughts on anything for the 2026 Model year for 4Runner? I know the vehicle is brand new, but...
So, the i-FORCE engine is solid for everyday driving. It’s got a good mix of power and...
