Can You Swap 5th and 6th Gen Wheels?
Blackteqrunner
Moderator
I’m curious if anyone knows the bore hub measurement on the 2025 6th gen and if it’s different from the 5th gen? I know the bolt patter is the same (6x139.7), but is it as simple as it is currently to swap and swap across platforms?
The reason I ask is I’m sure a lot of us are going to want to keep and swap our current aftermarket wheels when we get the new 4runner. If it’s similar to the Tacoma, and I suspect it is, then they might not be a direct swap. The bore length is different on the 3rd and 4th gen Tacomas. Thoughts?
The 2024 4th Gen Tacoma has a different hub bore now. It went from 106.1 down to 95.1, the bolt pattern is still 6X139.7.
If the new Tacoma has the same bolt pattern, I am sure the 4Runner will keep the same 6X139.7 bolt pattern as well. Because the new hub bore is smaller on the new Tacoma (likely the same on the 4Runner), we would just run a set of 106.1 to 95.1 hub-centric rings. Looks like these would work: https://www.amazon.com/WHEEL-CONNECT-Centric-Aluminium-Hubrings/dp/B0BH3RB3TZ?th=1
