Brand New 4Runner No audio
Konstantyn73
Brand New 4Runner Off Road JBL system No audio, no sound. Dial turning always at 0. Please Help...
Check the Mute Setting
Make sure the audio system isn't muted. Try pressing the Mute button on the dashboard or steering wheel and see if that restores sound.
Volume Control
Turn the volume knob both ways to ensure it’s not stuck at 0. Sometimes the knob may need to be pressed or turned repeatedly to reset it.
Check the Audio Source
Ensure that the correct audio source (radio, Bluetooth, USB, etc.) is selected. Try switching between sources to see if one has sound.
Settings
Go into the vehicle's Settings menu and check the audio settings. Resetting the audio preferences to default can sometimes resolve unexpected issues.
Vehicle Restart
Turn the engine off, exit the vehicle, and lock it. Wait a minute or two, then unlock and start the vehicle again to see if that resets the system.
Check for Software Updates
If you have a connected smartphone, check if there are any software updates available for the infotainment system via the Toyota app. Updates can fix bugs related to the audio system.
Disconnect the Battery
If none of the above works, you may want to disconnect the vehicle battery for 10-15 minutes to reset the system. Be sure to have the vehicle in a safe location with the engine off when doing this.
If none of this works, you might want to reach out to your local dealer.
Good day, today all of a sudden start working, but cant adjust the volume either knob nor on the steering wheel((
Next time I started the vehicle, again no sound...
Curious to see what other front-end lighting...
2025+ (6th Gen) Toyota 4Runner Trailhunter and...
Enjoy a photo dump of the new Trailhunter. Forum would only allow 10 images, so I picked some...
Curious to see what other front-end lighting setups you guys are running on either the factory...
I had to go pick up an axle for my crawler project, and the only thing I had was my 20' PJ...
2025+ (6th Gen) Toyota 4Runner Trailhunter and TRD Pro Factory Higher Clearance Bumper Part...
What is the largest tire size that can fit a completely stock 4runner? No trimming
