6th Gen 4Runner 74Weld Portal Axle Build Thread
I just posted this on Instagram the other day with the caption "6th Gen 4Runner on Portal Axles?....
The wheels are not mounted on the hubs, just leaning on the studs, but it gives you an idea of what it will potentially look like. Obviously the width is not going to be this extreme, but the height and general idea are there. Realistically, the width is going to come in about another 2-3" once the portals are on and the wheels are mounted on the hubs.
We're shooting to install some 74W portals on this thing in the next couple of months. I'll keep you guys posted.
Ok guys, it's official... the 74W portal axles have landed at StellarBuilt in Sacramento, and we're installing them this week. I will make this the dedicated 74Weld portal axle build thread; installation, wheel fitment, ground clearance specs before and after, etc. We have 37" Firestone Destination M/Ts going on our +25mm lock off-road beadlocks. The stance and fitment on the wheel/tire spec is going to be interesting. Technically, we should be running at least a +35mm wheel, and for the best tire fitment clearance, something like +45mm - +55mm wheel would really be ideal. Stay tuned, things are about to get interesting this week.
Portals have been installed. Sway bar has been deleted. We still have to swap new wheels on with a +25mm offset (currently on 0 offset), install new adjustable rear links from Dobinsons, finish wiring up the front Eaton e locker, and then we’re off to Dissent Offroad for full width front and rear bumpers + rock sliders. We also have a little bit of livery work to finalize as well. Finally, I’m waiting on some color (Ice Cap) matched rough country flares. The black flares work but I think wider color matched flares are going to look a bit better. It depends on what the stance looks like with the +25mm but we might color match our factory flares. Still unsure. We have about two weeks left until we hit the rubicon. But for now, portals are on. They drive amazing. Pretty stoked right now but a lot of work left.
Also removed the sway bar for a bit more articulation.
Dissent off-road front bumper. The first full-width "Mustache Delete" bumper on the market for the 6th Gen, and they absolutely killed it. The design aesthetic matches the upper mustache and the wings on the 6G very well. They really thought of everything for this front bumper.
Sensor placement on the wings and the center bumper frame
TSS relocation in the center of the bumper
Multiple louvers through the center bumper frame
Light mounting options for light bars and light pods on top of the bumper
Multiple top filler plates for whatever light style you want to run
Light pod cutouts in the bottom of the bumper frame
Tons of access to reach the winch power and clutch
Lots of room to run wires behind the bumper
And so much more. I'll have a full review dropping on this front bumper after we go test it on the Rubicon next week.
Dissent off-road rear bumper installed. For now, we're going with no swingouts for the Rubicon to keep the weight down. After we finish the Rubicon, we will likely install the swingouts for a spare tire and then go hit some overland stuff this next season. This rear bumper is absolutely stunning though. I'll have a full follow-up review thread on this rear bumper when we get back from the Rubicon.
How's that tie rod angle, with that only being unsprung full droop it looks maxed out, did you check it with a tire at full?
Looks killer, I'm beyond jealous...
We flexed it out to clearance the fenders and flares. Spent about 2 days just trimming and clearing flares and fenders to stuff the 37s. Also had to push my axle back about 1” with the Dobinsons rear upper and lower links.
Zero problems with tie rod axles at full droop though. Whole point of portals is not only ground clearance and a gear reduction but absolutely level CV angles and tie rod angles. Not 100% sure what you’re asking there. Maybe rephrase?
For some reference, this is Ben’s 250 on 40s and portals vs the 6th Gen 4Runner on portals and 37s. Looks small. lol plus we’re sitting a little wide right here because we’re on 0mm offset wheels and will be moving to a +25mm offset wheel to bring the track width in.
Took off the GFC SUPERLITE
Obviously money is no object. I was wondering what this project will set you back? ($) and what the MPG will end up being. This a project I have dreamed of since I discovered Unimogs, Pinzgauers and Volvo C303s.
Portals are $17k, labor $3k.
https://motorsports.74weld.com/product/4-gear-tacoma-4runner-portal/
Dissent front/rear bumpers: About $5k
https://dissentoffroad.com/collections/4runner
Dobinsons rear links: About $1000 for both
DOBINSONS REAR ADJUSTABLE TUBULAR STEEL SERIES LOWER TRAILING ARMS (PAIR)
DOBINSONS REAR ADJUSTABLE TUBULAR STEEL SERIES UPPER TRAILING ARMS (PAIR)
NYtop flares to match the width of the bumper $700-$1400
Those are the important mods for now. Everything else is just whatever you prefer. I still need a full suspension. Not sure what direction we're going, at the moment. MPG is still around 13 with the 37" M/Ts.
Wired the winch from the front to rear on the Hybrid using Dissents relocation kit. I wrote a whole thread on this.
Relocated the rear camera on the dissent bumper. The new cameras on these new gens have a few new wires, dual signal wires, video, audio, and others. Took us a bit to figure it out but we got it.
Relocated the windshield washer reservoir. Deleted the old one and used a universal reservoir to fit in between the headlight housing and the air dam plastics for the radiator. I made a few brackets that bolted in one spot but it wasn’t very stout. I ended up having Dissent make me a bracket that had a couple bends thanks to the press brake that mounted in two spots. I disconnected the factory pump and took a heatgun to the universal pump, moulding the factory pump into the plastic until it fit. This was quite the process but I got it to fit finally.
Dobinsons Extended rear links installed. Pushed back the axle about .75” initially and the tire was still pretty close to the rear fender well near the door, so we ended up adjusting it a week later and pushed it back another .25”. It’s still pretty close. I have no idea how we’re going to fit 40s on this thing. lol.
Wired up all the KC LIGHTS. Pro6 bar, rock lights, FE4 bumper lights, FE1 ditch lights and amber FE1 fog lights on the Dissent bumper.
Nytop fender flares went on.
Mounted the Air Down Gear Up drawer system with sleeper platform on the passenger side. It comes with a full sleeper system but you can delete one side if needed. Also these are the low height drawers since I have the hybrid.
On our way to up Rubicon at Fresh Pond the night before the first run.
Here are some shots from the Rubicon Portal Party...​
We've been planning this "Portal Party" for about 9 months now, and everyone was in crunch time mode to finish their builds. Everyone was still working the morning we started the trail. Some guys were wiring lights, some were still clearing tires, and I was cutting off my spare tire brackets because my track bar was colliding with them on uptravel. Because we pushed our axle back over 1", that causes the track bar to connect with the spare tire mounting brackets. So I ended up taking about 3" of the bracket off with a grinder. I was also wiring my front Eaton e-locker the night before at camp. It was all last-minute, but somehow we managed to pull it off and started the trail around 9 am.
We had quite a few builds on this trip.
Dissent Off-Road (Ben) 250 Land Cruiser
74Weld (Kristian) 4th Gen Tacoma
Stellar Built (Dima) 3rd Gen Tacoma
Taco Dust (Jason) 2nd Gen Tacoma
Flexus Frank (Frank) GX550
Trail4R (Brenan) 6th Gen 4Runner
All the builds were on 74Weld portals.
I'll try to post in chronological order of the trail. From the trailhead at Loon Lake to the Tahoma staging.
Update: There are too many photos to post in this build thread here. I will move this to a dedicated thread...
Wow - Exceptional build!! The folks at Thor Off Road have been helping me with mods on my TH and they were talking about putting portals on it - which is a little outside of what the significant other considers acceptable. And then you post this and I’m thinking how bad can it be to sleep in the Loafing Shed for a few months? The cows seem to like it just fine.
@3rdRunner yeah man, portals are a game changer. They drive great on the road (feels like stock just higher off the ground) and perform incredibly well off-road. The downside of portals is that once you experience them, it's hard to go back to mid-travel and even long travel. I doubt I'll go down the long travel rabbit hole of mods again after installing portals.
I believe that! And if you start with the Off Road you’re really not that far off a Pro or TH with some mods added - just a lot more capable. Smart move there.
