20% tint on all around
kophoto4x4
Got rid of the factory tint and swapped it out for Xpel 20% tint all around except the front windshield. I went with a ceramic tint and it really helps with the heat coming through the windows. It was really bad in direct sunlight hitting my arm but drove around today with it and didn't feel any heat! Highly recommend getting the tint done! I am in socal and got mine done from Coastline Tint and it cost me $575.
You had window film from the factory? I've never heard of that. Dealer-installed is all I've ever seen, and they never give you documentation on what brand/line they install.
PS is that a dark purple wrap?
im not too sure. my front windows were like a gradient there was none on the front two then it got a little dark on rear seats then a little more darker on the back windows.
its technically a satin red metallic but it looks more dark purple for sure
Usually the rear windows have a tint in the glass - it's maybe 20% (I could be wrong). Tint shops just tint over it. So if you had a 20% factory tint and then add 20% tint over the top you would be left with like 5% tint overall - almost limo tint. But yeah, factory tint is usually inside the glass.
Regardless, it's looking real good here.
Back around 2012 or so, Infiniti had a gloss version of a color that could be described that way, called Malbec Black. In bright sun it was either a deep purple or a deep burgundy red, depending on angle, but without the direct sun, it looked essentially black.
Agree it looks good. If you look at the markings on all your car windows, the windshield (all windshields) is marked AS1 (very high impact resistance and is clear except for a top few inch tinted portion (the AS1 line), and (on my older Tacoma anyway) the front side windows are marked AS2 and have a very light tint in the glass itself, and the rear windows are marked AS3 (darker tint, in the glass itself). Here's a little more info if anyone is interested: https://www.early911sregistry.org/f...erican-Standard-AS-numbers-safety-glass-codes
I'm convinced that Bend, Oregon is every overlanders dream. Trails for miles upon miles...
If any aftermarket parts brands are on here, someone please make an aftermarket solution to the...
Hey guys, We had a couple of customers come in looking to solve the 12V accessory wiring...
Hey all! Underground Sport Premium. 20' Nitto Ridge Grappler tires. Pretty much everything is...
I know the pro and trailhunter have wider fenders, but are the Off-road trims wider than the...
Yes they sure do. I have these laying around from my old fourth GEN and I decided to give them a...
After mocking up a few other wraps and livery concepts, I started to play around with the Turbo...
Has anyone encountered this yet with your new 4Runner? It’s starting to get humid here in FL and...
When at the New York Autoshow, I had the unique opportunity to have both a 4R Limited and LC250...
Seeing if anyone with other models have pre drilled threads in their frame for aftermarket rock...
Back at it with some wrap inspiration on the 6th Gen 4Runner. We have everything from multi-cam...
