Prinsu Pro Window Accessory Molle Panels Install 6th Gen 4Runner
The Prinsu accessory panel is a super-easy mod that you can add to your Prinsu Pro or original rack that opens up a ton of real estate for mounting accessories.
These new panels offer much more surface area than the previous versions seen on the 5th Gen 4Runner. Super stoked to get these installed. Let's take a look at the installation process and see what it's all about.
Today, we're installing the Pro version panel for the Pro rack.
We’re planning to install a GFC Superlite on the 6th Gen, so we’ll need accessory mounting options on the vehicle since the rooftop tent will be occupying the roof space.
Let me know if you guys have any questions.
1. Prepare the Accessory Panel and Side Rail Mount​
Start by laying out all the parts. Molle panel, hardware and suction cups.
2. Disconnect The Four Rear Crossbars​
Before disconnecting all four crossbars, put something underneath the bars so that the bars do not fall on your roof. I used a bit of foam that came in the packaging to prop up the bars. This also makes it easier to reinstall the crossbars and MOLLE panel mounting bracket.
3. Prepare New Hardware​
Your old hardware is probably caked with Loctite, so either clean your old hardware or grab some new 1" 1/4-20 hardware, add a little bit of blue Loctite, and install he mounting plate onto the side rail into the four crossbars.
4. Install Mounting Plate​
Hold the accessory panel top plate up next to the side rail.
Locate the crossbar bolts that were removed and mount the top plate to the side rails and into the crossbars.
5. Install Suction Cups on Panel​
Locate where to mount the suction cups. The panel is designed with two suction cup locations.
Install the suction cups on the panel.
Mock up where your panels go on the 4Runner. Prinsu provides a clear decal to protect the paint on your vehicle, as one suction cup will mount to the paint, not the window.
Ensure the suction cups are oriented correctly so you can access the pump button easily.
Now, remove the panel from the window and install the clear decal.
6. Mount MOLLE Panel to Mounting Plate​
Align the accessory panel with the two mounting holes on the top plate.
Reinstall the panel onto the window.
Start a couple of bolts to temporarily hold the panel in place.
Press firmly on the panel to compress the suction cups.
Depress the pump button until the suction cup is fully compressed.
7. Final Tightening​
Tighten the remaining hardware to secure everything in place.
You’re done. Now repeat the process on the other side if you have two panels.
Finished Result & Review​
The Prinsu Accessory Panel is a game-changer for adding some extra gear to your 6th Gen 4Runner; shovels, recovery gear, spare fuel, etc. It’s super easy to install, and the suction cups hold it firmly in place on both the paint and the window, giving you a sturdy spot for all your recovery gear or tools. The MOLLE slots make organizing anything incredibly simple, and it doesn’t take up any space in the cabin or on the roof. These panels are perfect for anyone who needs more storage but doesn’t want to clutter up the interior or for anyone looking to run an RTT on the roof rack.
We also installed an Agency6 Shovel Mount Combo - Black SSM (Surface Shovel Mount) with Knobs + the A6 Adventure Mini Shovel in Flat Dark Earth.
Shovel: https://www.tacomaforce.com/products/a6-adventure-mini-shovel-flat-dark-earth
Mount: https://agency6.com/collections/shovel-mount-components/products/ssm-shovel-surface-mount
Knobs: https://agency6.com/collections/shovel-mount-components/products/shovel-mount-knobs-pair
I've been running Agency6 stuff for a while now. Roughly 5+ years over many builds. I've run everything from their fairleads and winch shackles to shackle blocks and accessory mounts. They make really high-quality components - all machined right near me in Roseville, CA.
Check them out if you have not heard of them.
Im more of a home depot shovel guy but how is this one? You actually get some good leverage and pretty efficient?
Yeah, I hear you, it's always nice having a mid-size shovel, but not always easy to put one somewhere. These compact shovels are nice because they fit pretty much anywhere and essentially live on the build, so you'll always have something, just in case. For snow wheeling or sand trips, I usually make a point to bring a mid-size shovel with me, regardless of the mini. I've used the mini shovels quite a few times for random things - whether it's helping someone else out unexpectedly, needing a shovel while I'm not wheeling, or even just using it at the lake with my daughter... you'd be surprised how much they actually get used. Always something random. lol
This might be one of the best mods haha. It's functional for sure, but it adds another rad design element to really push that off-road look. I would buy them just for looks lol.
@Trail4R did you get some rubber plugs with the molle panels? What are they for? It's not in the instructions (actually their online PDF isn't even up to date) or install video?
@ClarkeBar - I do remember seeing those plugs, but I don't remember using them for anything. Not sure what those were for. If anyone knows, chime in. lol
I contacted CBI here's what they said...
"Typically we include them in case a customer wants to mount something like a rotopax on the panel. Those rubber stoppers are provided as "stands-offs" so that the rotopax doesnt sit on top of the button head screws on the face of the panel. This makes it so the rotopax (or other accessories) can sit parallel to the face."
TRD Pro Grille Swap on 6th Gen 4Runner - Not...
Finally got the Cali Raised LED fog light...
I want to thank WOLFBOX who contacted me about doing an installation and review on their new...
So Toyota actually gives us a couple factory skid plate options right out of the gate on the 6th...
Finally got the Cali Raised LED fog light replacement kit. Pretty affordable set of amber light...
CBI Sliders look amazing as usual. STOKED to get these mounted. We have a trip coming up here in...
Dissent Offroad Build – 2025+ (6th Gen) Toyota 4Runner TRD Off Road Premium Our 2025 TRD ORP...
White & Amber Switch Back OEM Fog Lights on the 6th Gen 4Runner The new 2025 Toyota 4Runner...
Ok guys, take a look at the new rack setup! We're running the Westcott Designs Lo-Pro (low...
Finally got around to taking some measurements on the 6th Gen today. Some of the most important...
What is the largest tire size that can fit a completely stock 4runner? No trimming
Incredibly stoked to share this one with you guys. The first drawer system on the market for the...
