- Aug 19, 2025
- 56
- 26
Roof Racks Available for 2025+ 4Runner
Drafting this up since roof racks are coming out right and left for the new 4Runner so I wanted to put them all in one place. Roof racks add serious utility: space for gear, rooftop tents, lights, and recovery boards. Some sit low and keep wind noise down, others go taller for more clearance and gear mounting, it all depends on how you want your rig to look and preform.Things to Consider
- Rack height and wind noise
- Mounting style and modularity
- Strength and load ratings for rooftop tents
Sherpa “The Capitol”
Built from aircraft-grade aluminum with stainless hardware, this no-drill rack fits cleanly to the 4Runner’s roofline and offers strong weight ratings.
- Nine crossbars
- 300 lb dynamic / 700 lb static load rating
Prinsu Pro
Fully modular aluminum rack with new Pro crossbars and formed side rails for added rigidity. Bolt-on, no-drill install with improved wind deflector.
- Modular crossbars with drop points
- Updated hardware system
Cali Raised Premium Rack
Low-profile aluminum rack with a built-in adjustable LED wind deflector that hides a light bar when not in use. It’s a sleek option that balances function with style.
- Adjustable LED fairing
- Bolt-on design, powder-coated finish
Rago Fabrication
Heavy-duty, low-profile design with eight crossmembers and durable powder coating. Made in the USA with a simple bolt-on install.
- Eight crossbars
- Compatible with tents and lights
Westcott Designs
Available in full-length and 3/4 setups, offering a factory-style look and plenty of mounting options.
- Aluminum build
- Bolt-on install
RCI Metalworks
RCI’s full-length rack is one of the more robust options available. It’s fully aluminum, bolt-on, and uses T-slot crossbars for easy mounting.
- 54 lb total weight
- About 3" of added roof height
Bison Gear OX PRO
Full-length modular rack designed for utility and clean looks.
- Adjustable crossbars
- Works with rooftop tents and recovery gear
