Prinsu Pro Window Accessory Molle Panels Install 6th Gen 4Runner
The Prinsu accessory panel is a super-easy mod that you can add to your Prinsu Pro or original rack that opens up a ton of real estate for mounting accessories.
These new panels offer much more surface area than the previous versions seen on the 5th Gen 4Runner. Super stoked to get these installed. Let's take a look at the installation process and see what it's all about.
Today, we're installing the Pro version panel for the Pro rack.
We’re planning to install a GFC Superlite on the 6th Gen, so we’ll need accessory mounting options on the vehicle since the rooftop tent will be occupying the roof space.
Let me know if you guys have any questions.
1. Prepare the Accessory Panel and Side Rail Mount​
Start by laying out all the parts. Molle panel, hardware and suction cups.
2. Disconnect The Four Rear Crossbars​
Before disconnecting all four crossbars, put something underneath the bars so that the bars do not fall on your roof. I used a bit of foam that came in the packaging to prop up the bars. This also makes it easier to reinstall the crossbars and MOLLE panel mounting bracket.
3. Prepare New Hardware​
Your old hardware is probably caked with Loctite, so either clean your old hardware or grab some new 1" 1/4-20 hardware, add a little bit of blue Loctite, and install he mounting plate onto the side rail into the four crossbars.
4. Install Mounting Plate​
Hold the accessory panel top plate up next to the side rail.
Locate the crossbar bolts that were removed and mount the top plate to the side rails and into the crossbars.
5. Install Suction Cups on Panel​
Locate where to mount the suction cups. The panel is designed with two suction cup locations.
Install the suction cups on the panel.
Mock up where your panels go on the 4Runner. Prinsu provides a clear decal to protect the paint on your vehicle, as one suction cup will mount to the paint, not the window.
Ensure the suction cups are oriented correctly so you can access the pump button easily.
Now, remove the panel from the window and install the clear decal.
6. Mount MOLLE Panel to Mounting Plate​
Align the accessory panel with the two mounting holes on the top plate.
Reinstall the panel onto the window.
Start a couple of bolts to temporarily hold the panel in place.
Press firmly on the panel to compress the suction cups.
Depress the pump button until the suction cup is fully compressed.
7. Final Tightening​
Tighten the remaining hardware to secure everything in place.
You’re done. Now repeat the process on the other side if you have two panels.
Finished Result & Review​
The Prinsu Accessory Panel is a game-changer for adding some extra gear to your 6th Gen 4Runner; shovels, recovery gear, spare fuel, etc. It’s super easy to install, and the suction cups hold it firmly in place on both the paint and the window, giving you a sturdy spot for all your recovery gear or tools. The MOLLE slots make organizing anything incredibly simple, and it doesn’t take up any space in the cabin or on the roof. These panels are perfect for anyone who needs more storage but doesn’t want to clutter up the interior or for anyone looking to run an RTT on the roof rack.
We also installed an Agency6 Shovel Mount Combo - Black SSM (Surface Shovel Mount) with Knobs + the A6 Adventure Mini Shovel in Flat Dark Earth.
Shovel: https://agency6.com/collections/shovels/products/a6-adventure-mini-shovel-flat-dark-earth
Mount: https://agency6.com/collections/shovel-mount-components/products/ssm-shovel-surface-mount
Knobs: https://agency6.com/collections/shovel-mount-components/products/shovel-mount-knobs-pair
I've been running Agency6 stuff for a while now. Roughly 5+ years over many builds. I've run everything from their fairleads and winch shackles to shackle blocks and accessory mounts. They make really high-quality components - all machined right near me in Roseville, CA.
Check them out if you have not heard of them.
Featured
I think this is the 2025 4Runner Platinum in...
The Prinsu accessory panel is a super-easy mod that you can add to your Prinsu Pro or original...
Installed a new set of Nova headlights from Alpharex. you have to remove the front bumper, to...
After installing our Peak Suspension 2.25" (front) and 2" (rear) lift kit, we thought we were...
I just wrapped up installing the Peak Suspension 2-piece collar lift kit on our 2025 TRD...
I will be putting a deposit on a Platinum, tomorrow (May 9th). Does anyone know when the factory...
I just crossed the 1000 mile mark on the 4Runner and wanted to give my thoughts so far. Some...
Between doing my research for the last 7 months and watching @TRD JON and @ToyotaJeff , it was...
I'm driving it from Maryland to Texas and already have thoughts (it's freakin' great) but I'll...
just got my TRD Pro last week - love it
Recently got the first oil change done at 2k miles. Since then I turned off eco mode and just...
We love a good tax break! I checked me weight on my ORP and it is over 6,000 pounds so there...
I finally got the Prinsu rack installed on the TRD Off-Road Premium and wanted to share a quick...
